The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and
rtems_configuration_is_smp_enabled() were added during the SMP support
development cycle as a workaround to fix some testsuite failures in SMP
configurations. All use cases were replaced with tests for specific
conditions. The configuration option and test macro were undocumented.
Close #3876.
Update #3533.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Do not use the processor count to determine if SMP is enabled. Instead
use a dedicated configuration option. Enable SMP by default in SMP
configurations.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
We may own the allocator mutex during context switches.
for details.
PR 1589/build
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am,
devfs04/Makefile.am, deviceio01/Makefile.am,
devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am,
gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am,
malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am,
malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am,
mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am,
tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am,
termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am,
termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional
manager capability.
* cpuuse/tswitch.c: Shrink memory requirements.
heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am: Revert.
termios01/init.c, termios02/Makefile.am: Fix bug so existing test
code for rtems_termios_baud_to_index() is executed.
* cpuuse/init.c, cpuuse/system.h: Use minimum stack size.
* cpuuse/tswitch.c: Eliminate use of deprecated rtems_extension.
* cpuuse/task1.c, termios/init.c: Convert calls to legacy routine
rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
* cpuuse/task1.c, cpuuse/tswitch.c, malloctest/task1.c,
stackchk/task1.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* cpuuse/tswitch.c: Lower sample count for small memory targets.
* cpuuse/system.h: Smaller stack size for small memory targets.
* monitor02/init.c: Cannot run on small memory targets.
* cpuuse/init.c, malloctest/init.c, monitor/init.c, monitor02/init.c,
putenvtest/init.c, rtems++/Init.cc, rtmonuse/init.c, stackchk/init.c:
Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all
POSIX tests. Add a clock_settime case for < 1988.
* cpuuse/task2.c, rtmonuse/rtmonuse.scn, rtmonuse/task1.c: Add new
cases for untested routines.
* cpuuse/init.c: Do not delete the Init task. Leaving it suspended lets
the CPU Usage Report include it. If it is deleted, the CPU time it
had consumed is not listed later in the report.
* cpuuse/Makefile.am, malloctest/Makefile.am, putenvtest/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Add
optional managers to Makefiles. Clean up test cases so last output
line follows END OF pattern. Make sure test case all run. All tests
appeared ok on sis.
* malloctest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* monitor/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* putenvtest/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* rtems++/System.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* rtmonuse/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* stackchk/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* termios/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* cpuuse/system.h, cpuuse/task1.c, cpuuse/tswitch.c, monitor/init.c,
monitor/system.h, rtems++/System.h, rtems++/Task1.cc,
rtems++/Task2.cc, rtems++/Task3.cc, rtmonuse/init.c,
rtmonuse/system.h, rtmonuse/task1.c, stackchk/blow.c: Convert to
using c99 fixed size types.
* cpuuse/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* malloctest/Makefile.am: Ditto.
* monitor/Makefile.am: Ditto.
* putenvtest/Makefile.am: Ditto.
* rtems++/Makefile.am: Ditto.
* rtmonuse/Makefile.am: Ditto.
* stackchk/Makefile.am: Ditto.
* termios/Makefile.am: Ditto.
* cpuuse/Makefile.am: Remove all-local: $(ARCH).
* malloctest/Makefile.am: Remove all-local: $(ARCH).
* monitor/Makefile.am: Remove all-local: $(ARCH).
* putenvtest/Makefile.am: Remove all-local: $(ARCH).
* rtems++/Makefile.am: Remove all-local: $(ARCH).
* rtmonuse/Makefile.am: Remove all-local: $(ARCH).
* stackchk/Makefile.am: Remove all-local: $(ARCH).
* termios/Makefile.am: Remove all-local: $(ARCH).
* cpuuse/init.c, cpuuse/system.h, cpuuse/task1.c, cpuuse/task2.c,
cpuuse/task3.c, cpuuse/tswitch.c, malloctest/init.c,
malloctest/system.h, malloctest/task1.c, monitor/init.c,
monitor/system.h, putenvtest/init.c, rtems++/Init.cc,
rtems++/System.h, rtems++/Task1.cc, rtems++/Task2.cc,
rtems++/Task3.cc, rtems++/rtems++.doc, rtmonuse/getall.c,
rtmonuse/init.c, rtmonuse/system.h, rtmonuse/task1.c,
stackchk/blow.c, stackchk/init.c, stackchk/system.h,
stackchk/task1.c: URL for license changed.
cpuuse/Makefile.am: Reflect having moved automake.
malloctest/Makefile.am: Reflect having moved automake.
monitor/Makefile.am: Reflect having moved automake.
putenvtest/Makefile.am: Reflect having moved automake.
rtems++/Makefile.am: Reflect having moved automake.
rtmonuse/Makefile.am: Reflect having moved automake.
stackchk/Makefile.am: Reflect having moved automake.
termios/Makefile.am: Reflect having moved automake.
* cpuuse/Makefile.am: Use $(OBJEXT) instead of .o.
* malloctest/Makefile.am: Use $(OBJEXT) instead of .o.
* monitor/Makefile.am: Use $(OBJEXT) instead of .o.
* putenvtest/Makefile.am: Use $(OBJEXT) instead of .o.
* rtems++/Makefile.am: Use $(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use $(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use $(OBJEXT) instead of .o.
* termios/Makefile.am: Use $(OBJEXT) instead of .o.
