* | Remove stray white spaces. | Ralf Corsepius | 2004-04-20 | 1 | -6/+6 |
* | * cpuuse/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. | Ralf Corsepius | 2004-04-01 | 1 | -1/+1 |
| | | | | | | | | | | * malloctest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * monitor/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * putenvtest/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * rtems++/System.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * rtmonuse/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * stackchk/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * termios/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-30 | 1 | -1/+1 |
| | | | | | | | | * cpuuse/system.h, cpuuse/task1.c, cpuuse/tswitch.c, monitor/init.c, monitor/system.h, rtems++/System.h, rtems++/Task1.cc, rtems++/Task2.cc, rtems++/Task3.cc, rtmonuse/init.c, rtmonuse/system.h, rtmonuse/task1.c, stackchk/blow.c: Convert to using c99 fixed size types. | ||||
| | | | | | | | | | | | | * cpuuse/init.c, cpuuse/system.h, cpuuse/task1.c, cpuuse/task2.c, cpuuse/task3.c, cpuuse/tswitch.c, malloctest/init.c, malloctest/system.h, malloctest/task1.c, monitor/init.c, monitor/system.h, putenvtest/init.c, rtems++/Init.cc, rtems++/System.h, rtems++/Task1.cc, rtems++/Task2.cc, rtems++/Task3.cc, rtems++/rtems++.doc, rtmonuse/getall.c, rtmonuse/init.c, rtmonuse/system.h, rtmonuse/task1.c, stackchk/blow.c, stackchk/init.c, stackchk/system.h, stackchk/task1.c: URL for license changed. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -4/+17 |
* | Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirements | Joel Sherrill | 1998-04-27 | 1 | -0/+2 |
| | | | | more accurate. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 1998-01-16 | 1 | -1/+1 |
| | | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | ||||
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | enabled floating point and fixed confdef reference to initialization | Joel Sherrill | 1997-04-09 | 1 | -0/+2 |
| | | | | tasks table. | ||||
* | new test | Joel Sherrill | 1997-04-09 | 1 | -0/+65 |
