Updates #3053.
Updates #3053.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3818.
Update #3382
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Use rtems_print_printer_fprintf_putc() instead of
rtems_print_printer_printf() to output via rtems_putc().
Update #3170.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
Avoid unnecessary use of CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM.
of this patch set.
For constant arguments GCC calculates the values of the math library
functions at compile-time.
close #1741
This reverts commit 0c2d8ec48a116cadb86564bc1226e308e197d4c1.
This reverts commit a80a108d447d596e476611108cd468ec993be4a6.
Use C pre-processor instead of shell commands.
for details.
* complex/init.c: Move configuration section.
* complex/docomplex.c, complex/docomplexf.c, complex/docomplexl.c:
Regenerate.
* complex/docomplex.in: Generate prototype docomplex* prototype.
* complex/Makefile.am, complex/init.c: Test now runs.
* math/init.c, complex/init.c:
Use fprintf(stdout,..) instead of printf.
Use CONFIGURE_APPLICATION_DISABLE_FILESYSTEM.
* configure.ac: Check for complex.h.
Add AM_CONDITIONAL(HAS_COMPLEX) to allow building with outdated
toolchains.
* complex/Makefile.am: Apply HAS_COMPLEX.
