* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | libtests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 1 | -0/+3 |
| | | | | Update #3818. | ||||
* | Revert "Revert "libtests/complex: Avoid generated files"" | Ralf Corsépius | 2012-05-31 | 1 | -99/+8 |
| | | | | This reverts commit 0c2d8ec48a116cadb86564bc1226e308e197d4c1. | ||||
* | Revert "libtests/complex: Avoid generated files" | Ralf Corsépius | 2012-05-31 | 1 | -8/+99 |
| | | | | This reverts commit a80a108d447d596e476611108cd468ec993be4a6. | ||||
* | Revert "Revert "libtests/complex: Avoid generated files"" | Ralf Corsépius | 2012-05-24 | 1 | -99/+8 |
* | Revert "libtests/complex: Avoid generated files" | Ralf Corsépius | 2012-05-23 | 1 | -8/+99 |
* | libtests/complex: Avoid generated files | Sebastian Huber | 2012-05-22 | 1 | -99/+8 |
| | | | | Use C pre-processor instead of shell commands. | ||||
* | 2011-12-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-13 | 1 | -1/+3 |
| | | | | | | * complex/init.c: Move configuration section. * complex/docomplex.c, complex/docomplexf.c, complex/docomplexl.c: Regenerate. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | New. | Ralf Corsepius | 2010-11-30 | 1 | -0/+110 |
