* | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 2014-12-16 | 1 | -2/+0 |
| | | | | This define was superfluous, undocumented and used inconsistently. | ||||
* | tests/libtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-20 | 1 | -2/+6 |
* | libblock: rtems_bdbuf_set_block_size() API change | Sebastian Huber | 2012-10-26 | 1 | -1/+1 |
| | | | | | | | The set block size must synchronize and purge the disk to avoid an inconsistent cache state and data corruption. The synchronization is optional depending on the new sync parameter. In some contexts a synchronization must not be performed, e.g. during disk creation. | ||||
* | libtests/block16: New test | Sebastian Huber | 2012-10-26 | 4 | -0/+185 |
