path: root/testsuites/libtests/block14 (follow)
* tests/libtests: Use <rtems/test.h>Sebastian Huber2014-03-201-2/+6
* libblock: Block device transfer request API changeSebastian Huber2012-11-021-1/+1
| | | | | | | | | | | | | | Add and use rtems_blkdev_request_done(). Block device transfer requests must signal the completion status now with rtems_blkdev_request_done(). The return value of the block device IO control will be ignored for transfer requests. The first parameter of rtems_blkdev_request_cb is now the transfer request structure. Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to break third party drivers at compile time, otherwise this API change would result in runtime errors.
* libblock: Add block device statisticsSebastian Huber2012-06-124-0/+273
