* | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 2014-12-16 | 1 | -2/+0 |
| | | | | This define was superfluous, undocumented and used inconsistently. | ||||
* | tests/libtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-20 | 1 | -2/+6 |
* | libblock: Block device transfer request API change | Sebastian Huber | 2012-11-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | Add and use rtems_blkdev_request_done(). Block device transfer requests must signal the completion status now with rtems_blkdev_request_done(). The return value of the block device IO control will be ignored for transfer requests. The first parameter of rtems_blkdev_request_cb is now the transfer request structure. Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to break third party drivers at compile time, otherwise this API change would result in runtime errors. | ||||
* | libblock: Add block device statistics | Sebastian Huber | 2012-06-12 | 4 | -0/+273 |
