* | tests/libtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-20 | 1 | -2/+6 |
* | libblock: Block device transfer request API change | Sebastian Huber | 2012-11-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | Add and use rtems_blkdev_request_done(). Block device transfer requests must signal the completion status now with rtems_blkdev_request_done(). The return value of the block device IO control will be ignored for transfer requests. The first parameter of rtems_blkdev_request_cb is now the transfer request structure. Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to break third party drivers at compile time, otherwise this API change would result in runtime errors. | ||||
* | libblock: Fix read-ahead trigger and next update | Sebastian Huber | 2012-07-02 | 1 | -5/+5 |
| | | | | | The previous version was sub-optimal for read-ahead transfer counts of one. | ||||
* | libblock: Fix read-ahead trigger and next update | Sebastian Huber | 2012-07-02 | 2 | -40/+52 |
* | libtests/block13: Add const qualifier | Sebastian Huber | 2012-06-04 | 1 | -1/+1 |
* | libblock: Add read-ahead task | Sebastian Huber | 2012-06-04 | 4 | -0/+273 |
Read-ahead requests were previously executed in the context of the reading task. This blocks the reading task until the complete read with read-ahead transfer is finished. A read-ahead task is introduced to off-load the read-ahead transfer. This allows the reading task to work with the requested block more quickly. The read-ahead is triggered after two misses of ascending consecutive blocks or a read hit of a block read by the most-recent read-ahead transfer. The read-ahead feature is configurable and can be disabled. |
