* | tests/libtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-20 | 1 | -2/+6 |
* | libblock: Block device transfer request API change | Sebastian Huber | 2012-11-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | Add and use rtems_blkdev_request_done(). Block device transfer requests must signal the completion status now with rtems_blkdev_request_done(). The return value of the block device IO control will be ignored for transfer requests. The first parameter of rtems_blkdev_request_cb is now the transfer request structure. Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to break third party drivers at compile time, otherwise this API change would result in runtime errors. | ||||
* | libblock: Add task stack size bdbuf configuration | Sebastian Huber | 2012-05-31 | 1 | -3/+1 |
| | | | | | | The task stack size for the swap-out and worker tasks is now configurable. The bdbuf task resources are now included in the work space size estimate. | ||||
* | libblock: Fix purge device tree traversal | Sebastian Huber | 2012-05-14 | 4 | -0/+185 |
