Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
This simplifies the RTEMS initialization and helps to avoid a memory
overhead. The workspace demands of the IO manager were not included in
the <rtems/confdefs.h> workspace size estimate. This is also fixed as a
side-effect.
Update documentation and move "Specifying Application Defined Device
Driver Table" to the section end. This sub-section is not that
important for the user. Mentioning this at the beginning may lead to
confusion.
This allows addtion of per disk statistics for example.
The task stack size for the swap-out and worker tasks is now
configurable. The bdbuf task resources are now included in the work
for details.
New functions
o rtems_blkdev_create(), and
o rtems_blkdev_create_partition().
New test libtests/block11.
