2022-04-12 | testsuites/libtests/[a-l]*: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2019-11-12 | block08: Use local include | Sebastian Huber | 1 | -1/+1 | |
Update #3818. | |||||
2016-05-25 | testsuite: Fix printk format warnings. | Chris Johns | 1 | -9/+7 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2012-03-13 | libblock: Change bdbuf API | Sebastian Huber | 1 | -2/+2 | |
The functions o rtems_bdbuf_get(), o rtems_bdbuf_read(), o rtems_bdbuf_syncdev(), and o rtems_bdbuf_purge_dev(), use now the disk device instead of the device identifier. This makes bdbuf independent of rtems_disk_obtain() and rtems_disk_release(). It is the responsiblity of the file system to obtain the disk device. This also reduces the overhead to get a buffer. The key for the AVL tree uses now the disk device instead of the device identifier. The pointer is interpreted as an unsigned integer. This reduces the memory overhead and makes the comparison operation a bit faster. Removed function rtems_bdbuf_purge_major(). This function was too destructive and could have unpredictable side effects. | |||||
2011-02-22 | Add HAVE_CONFIG_H. | Ralf Corsepius | 1 | -0/+4 | |
2010-01-19 | updates and new test cases | Thomas Doerfler | 1 | -0/+196 | |
