path: root/testsuites/libtests/block08/bdbuf_test1_4.c (follow)
* libblock: Change bdbuf APISebastian Huber2012-03-131-2/+2
| | | | | | | | | | | | | | | | | | | | The functions o rtems_bdbuf_get(), o rtems_bdbuf_read(), o rtems_bdbuf_syncdev(), and o rtems_bdbuf_purge_dev(), use now the disk device instead of the device identifier. This makes bdbuf independent of rtems_disk_obtain() and rtems_disk_release(). It is the responsiblity of the file system to obtain the disk device. This also reduces the overhead to get a buffer. The key for the AVL tree uses now the disk device instead of the device identifier. The pointer is interpreted as an unsigned integer. This reduces the memory overhead and makes the comparison operation a bit faster. Removed function rtems_bdbuf_purge_major(). This function was too destructive and could have unpredictable side effects.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* updates and new test casesThomas Doerfler2010-01-191-0/+179
