path: root/testsuites/libtests/block07 (follow)
* tests: Use rtems_task_exit()Sebastian Huber2018-10-051-3/+3
| | | | Update #3533.
* ramdisk: Use rtems_blkdev_create()Sebastian Huber2018-08-071-20/+33
| | | | Update #3358.
* testsuite/libtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-21/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Delete obsolete TESTS_USE_PRINTFSebastian Huber2017-11-021-1/+0
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-17/+19
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* cpukit, testsuite: Add rtems_printf and rtems_printer support.Chris Johns2016-05-251-2/+4
| | | | | | | | | | | | | | | | | | | This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work.
* Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEMSebastian Huber2014-12-161-1/+0
| | | | This define was superfluous, undocumented and used inconsistently.
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* tests/libtests: Use <rtems/test.h>Sebastian Huber2014-03-201-2/+6
* libblock: Add task stack size bdbuf configurationSebastian Huber2012-05-311-1/+1
| | | | | | The task stack size for the swap-out and worker tasks is now configurable. The bdbuf task resources are now included in the work space size estimate.
* libtmtests - Eliminate missing prototype warningsJoel Sherrill2012-05-111-0/+3
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-112-7/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* libblock: Change bdbuf APISebastian Huber2012-03-131-8/+11
| | | | | | | | | | | | | | | | | | | | The functions o rtems_bdbuf_get(), o rtems_bdbuf_read(), o rtems_bdbuf_syncdev(), and o rtems_bdbuf_purge_dev(), use now the disk device instead of the device identifier. This makes bdbuf independent of rtems_disk_obtain() and rtems_disk_release(). It is the responsiblity of the file system to obtain the disk device. This also reduces the overhead to get a buffer. The key for the AVL tree uses now the disk device instead of the device identifier. The pointer is interpreted as an unsigned integer. This reduces the memory overhead and makes the comparison operation a bit faster. Removed function rtems_bdbuf_purge_major(). This function was too destructive and could have unpredictable side effects.
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | PR 1589/build * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am, devfs04/Makefile.am, deviceio01/Makefile.am, devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am, gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am, malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am, tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am, termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am, termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional manager capability.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-0/+1
| | | | | | | | | | | | * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios02/Makefile.am: Revert.
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-1/+0
| | | | | | | | | | | | | * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios01/init.c, termios02/Makefile.am: Fix bug so existing test code for rtems_termios_baud_to_index() is executed.
* 2010-05-03 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Sebastian Huber2010-05-031-1/+0
| | | | | | * block01/init.c, block02/init.c, block03/init.c, block04/init.c, block05/init.c, block06/init.c, block07/init.c, block09/init.c, block10/init.c: Changed CONFIGURE_MAXIMUM_SEMAPHORES defines.
* 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-12-081-8/+8
| | | | | | | | | | * block01/init.c, block02/init.c, block03/init.c, block04/init.c, block05/init.c, block07/init.c, bspcmdline01/init.c, stringto01/init.c, stringto01/stringto_test_template.h, termios01/init.c, termios01/termios_testdriver.c, termios02/init.c: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure.
* added documentationThomas Doerfler2009-11-302-1/+27
| | | | | corrections in block tests added Makefile.am
* 2009-11-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-11-212-583/+2
| | | | | | | * block02/.cvsignore, block03/.cvsignore, block04/.cvsignore, block05/.cvsignore, block06/.cvsignore, block07/.cvsignore: New files. * block02/Makefile.in, block03/Makefile.in, block04/Makefile.in, block05/Makefile.in, block06/Makefile.in, block07/Makefile.in: Removed.
* New test caseThomas Doerfler2009-11-121-7/+54
* Added block05, block06 and block07Thomas Doerfler2009-11-094-0/+847
