path: root/testsuites/libtests/block03 (follow)
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-0/+1
| | | | | | | | | | | | * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios02/Makefile.am: Revert.
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-1/+0
| | | | | | | | | | | | | * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios01/init.c, termios02/Makefile.am: Fix bug so existing test code for rtems_termios_baud_to_index() is executed.
* 2010-05-03 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Sebastian Huber2010-05-031-1/+0
| | | | | | * block01/init.c, block02/init.c, block03/init.c, block04/init.c, block05/init.c, block06/init.c, block07/init.c, block09/init.c, block10/init.c: Changed CONFIGURE_MAXIMUM_SEMAPHORES defines.
* 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-12-081-7/+7
| | | | | | | | | | * block01/init.c, block02/init.c, block03/init.c, block04/init.c, block05/init.c, block07/init.c, bspcmdline01/init.c, stringto01/init.c, stringto01/stringto_test_template.h, termios01/init.c, termios01/termios_testdriver.c, termios02/init.c: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure.
* added documentationThomas Doerfler2009-11-302-1/+27
| | | | | corrections in block tests added Makefile.am
* 2009-11-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-11-212-583/+2
| | | | | | | * block02/.cvsignore, block03/.cvsignore, block04/.cvsignore, block05/.cvsignore, block06/.cvsignore, block07/.cvsignore: New files. * block02/Makefile.in, block03/Makefile.in, block04/Makefile.in, block05/Makefile.in, block06/Makefile.in, block07/Makefile.in: Removed.
* Added block02, block03 and block04Thomas Doerfler2009-10-294-0/+813
