* block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block06/init.c, block07/init.c, block09/init.c,
block10/init.c: Changed CONFIGURE_MAXIMUM_SEMAPHORES defines.
block05/init.c, block07/init.c, bspcmdline01/init.c,
stringto01/init.c, stringto01/stringto_test_template.h,
termios01/init.c, termios01/termios_testdriver.c, termios02/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
