Update #3382
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* POSIX/iconv.c, POSIX/iconv_open.c, POSIX/iconv_close.c: New.
* POSIX/Makefile.am: Add iconv, iconv_open, iconv_close.
* POSIX/clock_gettime.c, POSIX/gettimeofday.c: New.
* POSIX/Makefile.am: Add clock_gettime, gettimeofday.c.
* Makefile.am: Add clock_gettime, gettimeofday.c.
* POSIX/Makefile.am: Add htonl.
* POSIX/htonl.c: New.
* POSIX/sigfillset.c: Let main() return "status".
* POSIX/Makefile.am: Add sigaddset, sigdelset, sigemptyset,
sigismember.
* POSIX/sigaddset.c, POSIX/sigdelset.c, POSIX/sigemptyset.c,
POSIX/sigismember.c: New.
* POSIX/Makefile.am: Add wait.
* POSIX/wait.c: New.
