* ftp01/.cvsignore, ftp01/Makefile.am, ftp01/ftp01.doc,
ftp01/ftp01.scn, ftp01/init.c: New files.
* Makefile.am, configure.ac: Reflect changes above.
* Makefile.am, configure.ac: Add test for Mouse Parser Engine
(Microsoft Mouse paths) and Serial Mouse Driver.
* mouse01/.cvsignore, mouse01/Makefile.am, mouse01/init.c,
mouse01/mouse01.doc, mouse01/mouse01.scn, mouse01/msmouse.c,
mouse01/serial_mouse_config.c: New files.
* Makefile.am: Add complex, math subdirs.
* configure.ac: Add complex, math subdirs.
* gxx01/gxx_wrappers.h, gxx02/.cvsignore, gxx02/Makefile.am,
gxx02/gxx02.doc, gxx02/gxx02.scn, gxx02/init.c: Removed files.
* gxx01/init.c: Removed fatal error test case.
PR 1654/testing
* deviceio01/init.c, deviceio01/deviceio01.doc,
deviceio01/deviceio01.scn, deviceio01/test_driver.c,
deviceio01/test_driver.h, deviceio01/Makefile.am: New test added.
* Makefile.am, configure.ac: Changes to added above test.
* tar02/init.c, tar02/tar02.scn: New test case added: IMFS_dump().
* Makefile.am, configure.ac: Add test for rtems_print_buffer().
* dumpbuf01/.cvsignore, dumpbuf01/Makefile.am, dumpbuf01/dumpbuf01.doc,
dumpbuf01/dumpbuf01.scn, dumpbuf01/init.c: New files.
PR 1532/testing
* Makefile.am, configure.ac: Add initial tests for untar capabilities.
* tar01/.cvsignore, tar01/Makefile.am, tar01/init.c, tar01/tar01.doc,
tar01/tar01.scn, tar02/.cvsignore, tar02/Makefile.am, tar02/init.c,
tar02/tar02.doc, tar02/tar02.scn: New files.
PR 1631/testing
* gxx02/init.c, gxx02/gxx02.scn, gxx02/gxx02.doc,
gxx02/Makefile.am, gxx02/gxx_wrappers.h: New test added
* Makefile.am, configure.ac: Changes to accommodate new tests
PR 1632/testing
* Makefile.am, configure.ac: Make dedicated fatal error test for
/dev/null already registered. Using code from Bharath in new test
framework.
* devnullfatal01/.cvsignore, devnullfatal01/Makefile.am,
devnullfatal01/devnullfatal01.doc, devnullfatal01/devnullfatal01.scn,
devnullfatal01/testcase.h: New files.
* devfs02/init.c, devfs02/devfs02.doc, devfs02/devfs02.scn,
devfs02/Makefile.am: New tests added
* devfs03/init.c, devfs03/devfs03.doc, devfs03/devfs03.scn,
devfs03/Makefile.am: New tests added
* devfs04/init.c, devfs04/devfs04.doc, devfs04/devfs04.scn,
devfs04/Makefile.am: New tests added
* Makefile.am, configure.ac: Changes to accommodate the above
newly added tests.
* Makefile.am, configure.ac, termios06/init.c: Add initial tests for
XON/XOFF and VMIN/VMAX cases.
* termios07/.cvsignore, termios07/Makefile.am, termios07/init.c,
termios07/termios07.doc, termios07/termios07.scn,
termios08/.cvsignore, termios08/Makefile.am, termios08/init.c,
termios08/termios08.doc, termios08/termios08.scn: New files.
* Makefile.am, configure.ac: Add tar test for error cases.
* tar03/.cvsignore, tar03/Makefile.am, tar03/init.c, tar03/tar03.doc,
tar03/tar03.scn: New files.
* Makefile.am, configure.ac: Add new test to exercise devFS_Show().
* devfs01/.cvsignore, devfs01/Makefile.am, devfs01/devfs01.doc,
devfs01/devfs01.scn, devfs01/init.c: New files.
malloc_get_statistics().
* malloc05/.cvsignore, malloc05/Makefile.am, malloc05/init.c,
malloc05/malloc05.doc, malloc05/malloc05.scn: New files.
* Makefile.am, configure.ac: Add test for exercising sbrk() extension
to Malloc Family.
* malloc04/.cvsignore, malloc04/Makefile.am, malloc04/init.c,
malloc04/malloc04.doc, malloc04/malloc04.scn: New files.
* Makefile.am, configure.ac: tar01 and tar02 not merged yet.
* Makefile.am, configure.ac, malloc03/init.c: Add test for PPPDDISC.
* termios06/.cvsignore, termios06/Makefile.am, termios06/init.c,
termios06/termios06.doc, termios06/termios06.scn,
termios06/test_pppd.c: New files.
* Makefile.am, configure.ac: Add test for GCC C++ library helpers.
* gxx01/.cvsignore, gxx01/Makefile.am, gxx01/gxx01.doc,
gxx01/gxx01.scn, gxx01/gxx_wrappers.h, gxx01/init.c: New files.
* Makefile.am, configure.ac: Add test for task driven drivers.
* termios05/.cvsignore, termios05/Makefile.am, termios05/init.c,
termios05/termios05.doc, termios05/termios05.scn,
termios05/termios_testdriver_taskdriven.c,
termios05/termios_testdriver_taskdriven.h: New files.
* Makefile.am, configure.ac: Revert changes related to uncommitted test
under development.
* Makefile.am, configure.ac, malloctest/init.c, termios03/init.c,
termios03/termios03.scn: Handle some of the VKILL and VERASE cases.
* Makefile.am, configure.ac: Add new test to exercise termios RX and TX
interrupt driven IO support.
* termios04/.cvsignore, termios04/Makefile.am, termios04/init.c,
termios04/termios04.doc, termios04/termios04.scn,
termios04/termios_testdriver_intr.c,
termios04/termios_testdriver_intr.h: New files.
* termios03/.cvsignore, termios03/Makefile.am, termios03/init.c,
termios03/termios03.doc, termios03/termios03.scn,
termios03/termios_testdriver_polled.c,
termios03/termios_testdriver_polled.h: New files.
* Makefile.am, configure.ac: Add initial version of new test for polled
IO support in termios.
* Makefile.am, configure.ac: Added test that attempts to free stack
memory. This causes a error to be printed from the free function.
* malloc03/.cvsignore, malloc03/Makefile.am, malloc03/init.c,
malloc03/malloc03.doc, malloc03/malloc03.scn: New files.
* Makefile.am, configure.ac: Add test for deferring free() from ISR and
for deferred free() processing.
* malloc02/.cvsignore, malloc02/Makefile.am, malloc02/init.c,
malloc02/malloc02.doc, malloc02/malloc02.scn: New files.
* Makefile.am: Move POSIX in front of other tests.
* Makefile.am: Add POSIX.
* configure.ac: Add POSIX/.
* POSIX/calloc.c, POSIX/close.c, POSIX/COPYING, POSIX/dup2.c,
POSIX/fcntl.c, POSIX/fork.c, POSIX/free.c, POSIX/fstat.c,
POSIX/getdents.c, POSIX/getlogin.c, POSIX/getpwnam.c,
POSIX/getpwuid.c, POSIX/getuid.c, POSIX/issetugid.c,
POSIX/kill.c, POSIX/longjmp.c, POSIX/lseek.c, POSIX/lstat.c,
POSIX/Makefile.am, POSIX/Makefile.in, POSIX/malloc.c,
POSIX/nanosleep.c, POSIX/open.c, POSIX/pipe.c,
POSIX/posix_memalign.c, POSIX/read.c, POSIX/README,
POSIX/realloc.c, POSIX/setjmp.c, POSIX/sigfillset.c,
POSIX/sigprocmask.c, POSIX/stat.c, POSIX/unlink.c, POSIX/vfork.c,
POSIX/waitpid.c, POSIX/write.c: New.
* Makefile.am, configure.ac: Add string_to_xxx conversion test.
* stringto01/.cvsignore, stringto01/Makefile.am,
stringto01/stringto01.doc, stringto01/stringto01.scn,
stringto01/stringto_test_template.h: New files.
* Makefile.am, configure.ac, termios01/termios_testdriver.c: Do not use
CONSOLE_USE_INTERRUPTS. That is in use by BSPs and we should not use
it.
* termios02/.cvsignore, termios02/Makefile.am, termios02/init.c,
termios02/termios02.doc, termios02/termios02.scn: New files.
termios02 is a test for tcdrain().
* Makefile.am, configure.ac: Add initial test for
rtems_stack_checker_is_blown.
* stackchk01/.cvsignore, stackchk01/Makefile.am, stackchk01/init.c,
stackchk01/stackchk01.doc, stackchk01/stackchk01.scn: New files.
* Makefile.am, configure.ac: Add new test to exercise tcgetattr and
tcsetattr. Does a variety of baud, parity, stop bits, and bits per
character with the assistance of a special test driver which prints
the requests.
* termios01/.cvsignore, termios01/Makefile.am, termios01/init.c,
termios01/termios01.doc, termios01/termios01.scn,
termios01/termios_testdriver.c, termios01/termios_testdriver.h: New files.
* Makefile.am, configure.ac: Add test for new BSP Boot Command Line
helper routines.
* bspcmdline01/.cvsignore, bspcmdline01/Makefile.am,
bspcmdline01/bspcmdline01.doc, bspcmdline01/bspcmdline01.scn,
bspcmdline01/init.c, bspcmdline01/test.c: New files.
* Makefile.am, configure.ac: Add shell of heap walk test for Santosh.
* heapwalk/.cvsignore, heapwalk/Makefile.am, heapwalk/heapwalk.scn,
heapwalk/init.c, heapwalk/system.h: New files.
* Makefile.am, configure.ac: Added automatic test for monitor shell
* monitor02/Makefile.am, monitor02/init.c, monitor02/monitor02.scn,
monitor02/system.h: New files.
* Makefile.am, configure.ac: Added timezone test.
* tztest/Makefile.am, tztest/init.c, tztest/tztest.doc,
tztest/tztest.scn: New files.
* Makefile.am: Cleanup.
cpuuse/Makefile.am: Reflect having moved automake.
malloctest/Makefile.am: Reflect having moved automake.
monitor/Makefile.am: Reflect having moved automake.
putenvtest/Makefile.am: Reflect having moved automake.
rtems++/Makefile.am: Reflect having moved automake.
rtmonuse/Makefile.am: Reflect having moved automake.
stackchk/Makefile.am: Reflect having moved automake.
termios/Makefile.am: Reflect having moved automake.
* malloctest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* putenvtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems++/Makefile.am: Remove AUTOMAKE_OPTIONS.
* termios/Makefile.am: Remove AUTOMAKE_OPTIONS.
* libtests.am: Remove DEFS.
