Add the static files to the repository. This simplifies the build.
Update #3818.
This simplifies the build process. Do not generate the archive content
through the build system. Let the version control system deal with
symbolic links.
Update #3818.
Both need POSIX support
Update #3818.
Move system.h to shared init.c.
Update #3818.
Update #3818.
Update #3818.
Update #3818.
Update #3199.
This patch adds the ability for termios to send SIGINTR on receipt
of VINTR and SIGQUIT for VKILL and return -1/EINTR from read() on
a termios channel. Importantly, this patch does not alter the default
behavior or force POSIX signal code in just because termios is used.
The application must explicitly enable the POSIX behavior of generating
a signal upon receipt of these characters. This is discussed in the
POSIX standard:
https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/V1_chap11.html
Closes #3800.
It was accidentally committed.
This reverts commit a314544a278f1533ae001f742d7fe24fcee253e6.
Introduce new library librtemsrecordwrap.a which contains wrappers for
operating system functions which produce entry/exit events.
The wrappers can be selected during link time via the GNU ld --wrap
option.
Update #3665.
This is an example test using the RTEMS Test Framework. It tests also
the framework itself.
Add T_FILE_NAME command line define to get rid of the full file path.
This is important to reduce the read-only data of test files and make
them build system independent.
Update #3199.
- The archive command lists archives, symbols and any duplicate
symbols.
- Change the RTL shell commands to the rtems_printer to allow
the output to be captured.
- Add support for architecure sections that can be handled by the
architecture back end.
- Add trampoline/fixup support for PowerPC. This means the PowerPC
now supports large memory loading of applications.
- Add a bit allocator to manage small block based regions of memory.
- Add small data (sdata/sbss) support for the PowerPC. The support
makes the linker allocated small data region of memory a global
resource available to libdl loaded object files.
Updates #3687
Updates #3685
- Add trampolines to support relocs that are out of range on
support architectures.
- Support not loading separate text/data sections in an object
file if the symbol provided in the section is a duplicate.
A base image may have pulled in part of an object and another
part needs to be dynamically loaded.
- Refactor the unresolved handling to scale to hundreds of
unresolved symbols when loading large number of files.
Updates #3685
- Trampolines or fixups for veneers provide long jump support
for instruciton sets that implement short relative address
branches. The linker provides trampolines when creating a
static image. This patch adds trampoline support to libdl
and the ARM architecture.
- The dl09 test requires enough memory so modules are outside
the relative branch instruction ranges for the architecture.
Updates #3685
- Create 2 archives.
- Load 1 object file which loads 6 object files from the libraries.
Updates #3686
Add low level event recording infrastructure for system and user
defined events. The infrastructure is able to record high frequency
events such as
* SMP lock acquire/release,
* interrupt entry/exit,
* thread switches,
* UMA zone allocate/free, and
* Ethernet packet input/output, etc.
It allows post-mortem analysis in fatal error handlers, e.g. the last
events are in the record buffer, the newest event overwrites the oldest
event. It is possible to detect record buffer overflows for consumers
that expect a continuous stream of events, e.g. to display the system
state in real-time.
The implementation supports high-end SMP machines (more than 1GHz
processor frequency, more than four processors).
Add a new API instead. The implementation uses per-processor data
structures and no atomic read-modify-write operations. It is uses
per-processor ring buffers to record the events.
The CPU counter is used to get the time of events. It is combined with
periodic uptime events to synchronize it with CLOCK_REALTIME.
The existing capture engine tries to solve this problem also, but its
performance is not good enough for high-end production systems. The
main issues are the variable-size buffers and the use of SMP locks for
synchronization. To fix this, the API would change significantly.
Update #3665.
This enables support for non-standard compiler names, e.g.
sparc-rtems6-gcc.
sparc-rtems6-gcc.
Tracking references lets us manage when an object file can be
unloaded. If an object file has references to it, it cannot be
unloaded.
Modules that depend on each other cannot be unloaded.
Updates #3605
Update #3551.
An RTEMS application default configuration is contained in
cpukit/libmisc/dummy/default-configuration.c. This default
configuration was contained in librtemscpu.a. This had at least two
problems:
1. Application configuration errors may have pulled in the default
configuration which in turn lead to multiply define symbols error.
This was quite confusing. You had to consult the linker map file to
figure out what cased the pull in of the default configuration. You
needed to know what a linker map file is and how you generate it with
your build system. This was not very user friendly.
2. It prevented the use of default configuration items for each subsystem
in librtemscpu.a. This may be used to reduce the size of the
configuration itself.
Move the default configuration to the separate library
librtemsdefaultconfig.a.
Close #3551.
closes #3401, #3402.
The Telnet service started via rtems_telnetd_start() had a keep stdio
feature. This just created a task and executed the command function in
a loop. For this kind of service we do not library support. This can
be done by an application task on its own. Remove this feature and
provide only the real Telnet server functionality.
Use syslog() for error and status messages.
Add test program for the Telnet server.
Close #3542.
Remove use of TMPINSTALL_FILES.
Move FTP client filesystem to separate library libftpfs.a.
Update #3419.
Always build remote TCP support since it depends only on the POSIX
socket API. It works with the legacy network stack and libbsd. Move it
to a separate libdebugger.a library to allow an easy use with libbsd via
"-ldebugger -lbsd" otherwise we would have a cyclic dependency between
libbsd.a and librtemscpu.a.
Update #3419.
This test loads a RAP format file that contains calls that are not
in the kernel and linked from libm. It uses and test rtems-ld.
Update #2769
Update #3382
Update #3239.
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
In case carriage return characters should be ignored in the input
(IGNCR), then drop them early before they reach the raw input buffer.
This makes it easier to calculate the content size of the raw input
buffer.
User API is compatible to Linux userspace API. New test libtests/spi01.
Update #2776.
This is old and there are better design patterns for threading and C++.
We recommend you use the new C++ standards based support.
Closes #2777.
This implementation just falls back to giving a string representation of
the IP. It supports IPv4 only.
Add test for getnameinfo().
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
The dummy.c was a de-facto default configuration. Rename it to
default-configuration.c. Use unlimited objects and the stack checker.
This makes it easier for new RTEMS users which will likely use this file
if they just work with the usual main() function as the application
entry point. Provide proper arguments for main() using the BSP command
line. Add spare user extensions and drivers.
Do not initialize the network by default. Delete bspinit.c.
Use the heap handler statistics instead. Add heap walk option to MALLOC
shell command.
close #1367
