* itronmbf01/init.c, itronsem01/init.c, itronsem01/system.h,
itrontask02/dormant.c, itrontask02/init.c, itrontask03/init.c,
itrontask03/preempt.c: Use rtems_test_assert() consistently instead
of system assert(). rtems_test_assert() is designed to integrate into
the RTEMS test suite infrastructure.
* itrontime01/init.c: Use %ld to print "time"s.
* itrontime01/init.c: Use "long"s for "time"s (16bit compliance).
* itrontask04/task3.c: Add missing prototypes.
* itrontask02/system.h, itrontask03/system.h, itrontask04/system.h:
* itrontask02/dormant.c: Add missing prototypes.
* itrontask01/task1.c: Add missing prototypes.
* itrontask01/system.h: Add missing prototypes.
* itronsem01/init.c: Use PRId32 to print INT's.
* itronmbf01/init.c: Add missing prototypes.
* itrontask01/task1.c, itrontask02/dormant.c, itrontask03/task1.c,
itrontask03/task2.c, itrontask03/task3.c, itrontask04/task3.c:
Eliminate test routines TICKS_PER_SECOND and get_ticks_per_second()
in favor of new rtems_clock_get_ticks_per_second().
* itrontask01/task1.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am:
Eliminate _exe_/.exe.
* itrontask04/init.c: Run all tests successfully with maxixum number of
priorities as 16 instead of 256. This was done by temporarily
modifying the score priority.h maximum. This allowed testing of all
API code to ensure that it worked properly with a reduced number of
priorities. Most modifications were to switch from hard-coded maximum
to using the API provided methods to determine maximum number of
priority levels.
* itronhello/system.h, itronmbox01/system.h, itrontask02/system.h,
itrontime01/system.h: Add use of
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
* itronhello/init.c, itronmbf01/init.c, itronmbox01/init.c,
itronsem01/init.c, itrontask01/init.c, itrontask02/init.c,
itrontask03/init.c, itrontask04/init.c, itrontime01/init.c: Change
TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX
tests. Add a clock_settime case for < 1988.
* itronmbf01/init.c, itronmbf01/itronmbf01.scn, itrontask02/init.c,
itrontask03/itrontask03.scn, itrontask03/task1.c,
itrontask04/itrontask04.scn, itrontask04/task3.c: Add optional
managers to Makefiles. Clean up test cases so last output line
follows END OF pattern. Make sure test case all run. All tests
appeared ok on sis.
* itronmbf01/init.c: Address size_t/uint32_t typing issues in message
queue tests.
* itrontask04/init.c, itrontask04/itrontask04.scn: Cannot print with
dispatching disabled so fix test not to print while dispatching is
disabled.
itrontime01/Makefile.am: Eliminate scndir, docdir. Use
rtems_testsdir instead.
* configure.ac: Remove RTEMS_ENABLE_BARE,
BARE_CPU_CFLAGS, BARE_CPU_MODEL.
Convert to using *_PROGRAMS.
* itronmbf01/Makefile.am: Rework.
* itronmbox01/Makefile.am: Rework.
* itronsem01/Makefile.am: Rework.
* itrontask01/Makefile.am: Rework.
* itrontask02/Makefile.am: Rework.
* itrontask03/Makefile.am: Rework.
* itrontask04/Makefile.am: Rework.
* itrontime01/Makefile.am: Rework.
itrontime01/Makefile.am: Expand itrontests.am.
* itrontests.am: Remove.
AM_CPPFLAGS += -I..../support/include.
* itrontests.am: Set project_bspdir=$(PROJECT_ROOT)
* itrontests.am: Remove LIB_VARIANT.
* itrontests.am: Add $(PGM): ${ARCH}/$(dirstamp).
Partial conversion to automake.
* Makefile.am: Cleanup.
PR 721/tests
* itronsem01/init.c: Fix bogus assert.
