* itrontests.am: Remove DEFS.
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
to fail sporadically.
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
Addtional major bugs:
critical.
This should result in nothing happening, but an E_OK result.
parts as a reminder to fix when these routines became implemented.
then sta_tsk used to restart the task to its initial state.
+ Added calls to ref_tsk to yellow paths for suspended and
ready but not running tasks.
+ Fixed output file to correctly state test name
+ Added priority of preempt to the header file. Allows ref_tsk verification.
state and one that is in non-dormant state.
+ Increased the priority of the Init task to force the dummy tasks to
run first.
+ Added calls to ref_tsk to verify the state of the dummy tasks and
test ref_tsk.
+ Modified calls to use the task id macro for calls to the PREEMPT task.
+ Modified output to correctly state the error.
Changed output to reflect what was actually being tested.
Increased stack space.
prints a message instead of actually testing since the message buffer
implementation is not in yet.
and adding code which installed screens for itron tests.
for RTEMS.
