* | Fixed warnings. | Joel Sherrill | 2000-01-04 | 2 | -2/+1 |
* | Uncommitted remains of a previous patch from Ralf Corsepius | Joel Sherrill | 1999-11-30 | 10 | -0/+410 |
| | | | | <corsepiu@faw.uni-ulm.de> which converted fiels to automake. | ||||
* | Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-29 | 1 | -9/+3 |
| | | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working) | ||||
* | Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 1 | -1/+0 |
| | | | | to fix some minor bugs in the conversion to automake. | ||||
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 34 | -50/+52 |
* | New shell of a test for ITRON Mailbox Manager. | Joel Sherrill | 1999-11-17 | 5 | -1/+70 |
* | Inserted output from the erc32 run into the output file. | Jennifer Averett | 1999-11-16 | 1 | -3/+71 |
* | Use miniIMFS like hello from samples. | Joel Sherrill | 1999-11-16 | 1 | -0/+2 |
* | Increased stack space because message buffers are on the stack. | Joel Sherrill | 1999-11-16 | 1 | -0/+1 |
* | Added data to the log file so it matches the real output. | Jennifer Averett | 1999-11-16 | 1 | -3/+61 |
* | Added comment to log file indicating that task order is not | Jennifer Averett | 1999-11-16 | 1 | -1/+3 |
| | | | | critical. | ||||
* | Added test case of rsm_tsk and frsm_tsk on a task not suspended. | Jennifer Averett | 1999-11-16 | 2 | -3/+14 |
| | | | | This should result in nothing happening, but an E_OK result. | ||||
* | Changed asserts to tmmacros. | Jennifer Averett | 1999-11-16 | 2 | -8/+7 |
* | Updated scn file to match new output. Left out unemplemented | Jennifer Averett | 1999-11-16 | 1 | -17/+12 |
| | | | | parts as a reminder to fix when these routines became implemented. | ||||
* | + Changed ID to 1. ( Compilation error introduced by modifications. ) | Jennifer Averett | 1999-11-16 | 1 | -1/+1 |
* | Modified scan file to match. | Jennifer Averett | 1999-11-16 | 1 | -2/+2 |
* | Changed to call tmmacros instead of assert. | Jennifer Averett | 1999-11-16 | 1 | -141/+153 |
* | Fixed verificaiton checks to call correct macro if dispatch is disabled. | Jennifer Averett | 1999-11-15 | 1 | -7/+12 |
* | + Added check that a task could be sent to a dormant state | Jennifer Averett | 1999-11-15 | 4 | -12/+94 |
| | | | | | | | | then sta_tsk used to restart the task to its initial state. + Added calls to ref_tsk to yellow paths for suspended and ready but not running tasks. + Fixed output file to correctly state test name + Added priority of preempt to the header file. Allows ref_tsk verification. | ||||
* | + Changed preempt routine into two dummy tasks one that is in dormant | Jennifer Averett | 1999-11-15 | 3 | -14/+94 |
| | | | | | | | | state and one that is in non-dormant state. + Increased the priority of the Init task to force the dummy tasks to run first. + Added calls to ref_tsk to verify the state of the dummy tasks and test ref_tsk. | ||||
* | + Modified calls to use TSK_SLF for calls to self. | Joel Sherrill | 1999-11-12 | 1 | -25/+24 |
| | | | | + Modified calls to use the task id macro for calls to the PREEMPT task. | ||||
* | + Added comments on paths tested. | Joel Sherrill | 1999-11-12 | 2 | -1/+14 |
* | + Added check for priority over 256. | Joel Sherrill | 1999-11-12 | 1 | -1/+4 |
| | | | | + Modified output to correctly state the error. | ||||
* | Added comments for path's tested. | Joel Sherrill | 1999-11-12 | 1 | -0/+3 |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 6 | -8/+9 |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 2 | -6/+11 |
| | | | | Changed output to reflect what was actually being tested. | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 4 | -5/+9 |
| | | | | Increased stack space. | ||||
* | Enabled after merging message buffer code. | Joel Sherrill | 1999-11-12 | 1 | -6/+2 |
* | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1999-11-10 | 15 | -22/+81 |
| | | | | | prints a message instead of actually testing since the message buffer implementation is not in yet. | ||||
* | Combination of committing some new files which had been overlooked | Joel Sherrill | 1999-11-10 | 5 | -1/+95 |
| | | | | and adding code which installed screens for itron tests. | ||||
* | Added more tasking tests. | Joel Sherrill | 1999-11-09 | 1 | -1/+2 |
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 30 | -38/+1553 |
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 10 | -0/+969 |
for RTEMS. |
