* itrontests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am:
Partial conversion to automake.
PR 721/tests
* itronsem01/init.c: Fix bogus assert.
* itronmbf01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itronmbox01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontime01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itronhello/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itronmbf01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itronmbox01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask02/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask03/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask04/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontime01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* configure.ac: Add 2nd arg to RTEMS_TOP.
* itronhello/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* itronmbf01/Makefile.am: Ditto.
* itronmbox01/Makefile.am: Ditto.
* itronsem01/Makefile.am: Ditto.
* itrontask01/Makefile.am: Ditto.
* itrontask02/Makefile.am: Ditto.
* itrontask03/Makefile.am: Ditto.
* itrontask04/Makefile.am: Ditto.
* itrontime01/Makefile.am: Ditto.
* itrontests.am: Add dirstamp support.
* itrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* itronhello/Makefile.am: Remove all-local: $(ARCH).
* itronmbf01/Makefile.am: Remove all-local: $(ARCH).
* itronmbox01/Makefile.am: Remove all-local: $(ARCH).
* itronsem01/Makefile.am: Remove all-local: $(ARCH).
* itrontask01/Makefile.am: Remove all-local: $(ARCH).
* itrontask02/Makefile.am: Remove all-local: $(ARCH).
* itrontask03/Makefile.am: Remove all-local: $(ARCH).
* itrontask04/Makefile.am: Remove all-local: $(ARCH).
* itrontime01/Makefile.am: Remove all-local: $(ARCH).
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac:Remove RTEMS_CHECK_CPU.
* itronhello/init.c, itronhello/itronhello.doc, itronhello/system.h,
itronmbf01/init.c, itronmbf01/itronmbf01.doc, itronmbf01/system.h,
itronmbox01/init.c, itronmbox01/system.h, itronsem01/init.c,
itronsem01/itronsem01.doc, itronsem01/system.h, itrontask01/init.c,
itrontask01/itrontask01.doc, itrontask01/system.h,
itrontask01/task1.c, itrontask02/dormant.c, itrontask02/init.c,
itrontask02/itrontask02.doc, itrontask02/system.h,
itrontask03/init.c, itrontask03/itrontask03.doc,
itrontask03/preempt.c, itrontask03/system.h, itrontask03/task1.c,
itrontask03/task2.c, itrontask03/task3.c, itrontask04/init.c,
itrontask04/itrontask04.doc, itrontask04/system.h,
itrontask04/task1.c, itrontask04/task2.c, itrontask04/task3.c,
itrontime01/init.c, itrontime01/system.h: URL for license changed.
itronhello/Makefile.am: Reflect having moved automake.
itronmbf01/Makefile.am: Reflect having moved automake.
itronmbox01/Makefile.am: Reflect having moved automake.
itronsem01/Makefile.am: Reflect having moved automake.
itrontask01/Makefile.am: Reflect having moved automake.
itrontask02/Makefile.am: Reflect having moved automake.
itrontask03/Makefile.am: Reflect having moved automake.
itrontask04/Makefile.am: Reflect having moved automake.
itrontime01/Makefile.am: Reflect having moved automake.
* configure.ac: Remove CC_CFLAGS_DEBUG_V.
CC_CFLAGS_DEFAULT (obsolete).
* configure.ac: Remove CC_CFLAGS_PROFILE_V.
Remove CC_LDFLAGS_PROFILE_V.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* itronhello/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronmbf01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronmbox01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask02/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask03/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask04/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontime01/Makefile.am: Use .$(OBJEXT) instead of .o.
enable this support.
* itronhello/init.c, itronmbf01/init.c, itronmbox01/init.c,
itronsem01/init.c, itrontask01/task1.c, itrontask02/init.c,
itrontask03/task1.c, itrontask04/task3.c, itrontime01/init.c: Modified.
* itronhello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbf01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbox01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontime01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* itrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* itrontask03/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask04/Makefile.am: include leaf.am instead of leaf.cfg.
* itronmbf01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronhello/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontime01/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask01/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask02/Makefile.am: include leaf.am instead of leaf.cfg.
* itronmbox01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronmbf01/itronmbf01.scn, itronmbox01/init.c,
itronsem01/itronsem01.scn, itrontime01/init.c: Various
adjustments so test output matches screens more reliably.
* itrontask01/system.h: Configure enough stack memory.
* itrontests.am: Remove DEFS.
itrontime01/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
