path: root/testsuites/itrontests (follow)
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-273-2/+8
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * itrontests.am: Remove DEFS.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0510-0/+17
| | | | | | | | * itronhello/Makefile.am, itronmbf01/Makefile.am, itronmbox01/Makefile.am, itronsem01/Makefile.am, itrontask01/Makefile.am, itrontask02/Makefile.am, itrontask03/Makefile.am, itrontask04/Makefile.am, itrontime01/Makefile.am: Include compile.am
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1221-61/+81
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-1310-0/+31
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-319-9/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Initialize the attributes structure. Random data was causing the testJoel Sherrill2000-01-061-0/+2
| | | | to fail sporadically.
* Fixed warnings.Joel Sherrill2000-01-042-2/+1
* Uncommitted remains of a previous patch from Ralf CorsepiusJoel Sherrill1999-11-3010-0/+410
| | | | <corsepiu@faw.uni-ulm.de> which converted fiels to automake.
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-291-9/+3
| | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working)
* Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-1/+0
| | | | to fix some minor bugs in the conversion to automake.
* + Updated copyright information.Jennifer Averett1999-11-1734-50/+52
* New shell of a test for ITRON Mailbox Manager.Joel Sherrill1999-11-175-1/+70
* Inserted output from the erc32 run into the output file.Jennifer Averett1999-11-161-3/+71
* Use miniIMFS like hello from samples.Joel Sherrill1999-11-161-0/+2
* Increased stack space because message buffers are on the stack.Joel Sherrill1999-11-161-0/+1
* Added data to the log file so it matches the real output.Jennifer Averett1999-11-161-3/+61
* Added comment to log file indicating that task order is notJennifer Averett1999-11-161-1/+3
| | | | critical.
* Added test case of rsm_tsk and frsm_tsk on a task not suspended.Jennifer Averett1999-11-162-3/+14
| | | | This should result in nothing happening, but an E_OK result.
* Changed asserts to tmmacros.Jennifer Averett1999-11-162-8/+7
* Updated scn file to match new output. Left out unemplementedJennifer Averett1999-11-161-17/+12
| | | | parts as a reminder to fix when these routines became implemented.
* + Changed ID to 1. ( Compilation error introduced by modifications. )Jennifer Averett1999-11-161-1/+1
* Modified scan file to match.Jennifer Averett1999-11-161-2/+2
* Changed to call tmmacros instead of assert.Jennifer Averett1999-11-161-141/+153
* Fixed verificaiton checks to call correct macro if dispatch is disabled.Jennifer Averett1999-11-151-7/+12
* + Added check that a task could be sent to a dormant stateJennifer Averett1999-11-154-12/+94
| | | | | | | | then sta_tsk used to restart the task to its initial state. + Added calls to ref_tsk to yellow paths for suspended and ready but not running tasks. + Fixed output file to correctly state test name + Added priority of preempt to the header file. Allows ref_tsk verification.
* + Changed preempt routine into two dummy tasks one that is in dormantJennifer Averett1999-11-153-14/+94
| | | | | | | | state and one that is in non-dormant state. + Increased the priority of the Init task to force the dummy tasks to run first. + Added calls to ref_tsk to verify the state of the dummy tasks and test ref_tsk.
* + Modified calls to use TSK_SLF for calls to self.Joel Sherrill1999-11-121-25/+24
| | | | + Modified calls to use the task id macro for calls to the PREEMPT task.
* + Added comments on paths tested.Joel Sherrill1999-11-122-1/+14
* + Added check for priority over 256.Joel Sherrill1999-11-121-1/+4
| | | | + Modified output to correctly state the error.
* Added comments for path's tested.Joel Sherrill1999-11-121-0/+3
* Test name changed to reflect placement after merger.Joel Sherrill1999-11-126-8/+9
* Test name changed to reflect placement after merger.Joel Sherrill1999-11-122-6/+11
| | | | Changed output to reflect what was actually being tested.
* Test name changed to reflect placement after merger.Joel Sherrill1999-11-124-5/+9
| | | | Increased stack space.
* Enabled after merging message buffer code.Joel Sherrill1999-11-121-6/+2
* General cleanup. Test documentation improved. The message buffer testJoel Sherrill1999-11-1015-22/+81
| | | | | prints a message instead of actually testing since the message buffer implementation is not in yet.
* Combination of committing some new files which had been overlookedJoel Sherrill1999-11-105-1/+95
| | | | and adding code which installed screens for itron tests.
* Added more tasking tests.Joel Sherrill1999-11-091-1/+2
* Merged tests from Task group.Joel Sherrill1999-11-0930-38/+1553
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-0910-0/+969
for RTEMS.
