* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 2 | -6/+11 | |
| | | | | Changed output to reflect what was actually being tested. | |||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 4 | -5/+9 | |
| | | | | Increased stack space. | |||||
* | Enabled after merging message buffer code. | Joel Sherrill | 1999-11-12 | 1 | -6/+2 | |
* | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1999-11-10 | 15 | -22/+81 | |
| | | | | | prints a message instead of actually testing since the message buffer implementation is not in yet. | |||||
* | Combination of committing some new files which had been overlooked | Joel Sherrill | 1999-11-10 | 5 | -1/+95 | |
| | | | | and adding code which installed screens for itron tests. | |||||
* | Added more tasking tests. | Joel Sherrill | 1999-11-09 | 1 | -1/+2 | |
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 30 | -38/+1553 | |
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 10 | -0/+969 | |
for RTEMS. |
