1999-11-16 | Modified scan file to match. | Jennifer Averett | 1 | -2/+2 | |
1999-11-16 | Changed to call tmmacros instead of assert. | Jennifer Averett | 1 | -141/+153 | |
1999-11-15 | Fixed verificaiton checks to call correct macro if dispatch is disabled. | Jennifer Averett | 1 | -7/+12 | |
1999-11-15 | + Added check that a task could be sent to a dormant state | Jennifer Averett | 4 | -12/+94 | |
then sta_tsk used to restart the task to its initial state. + Added calls to ref_tsk to yellow paths for suspended and ready but not running tasks. + Fixed output file to correctly state test name + Added priority of preempt to the header file. Allows ref_tsk verification. | |||||
1999-11-15 | + Changed preempt routine into two dummy tasks one that is in dormant | Jennifer Averett | 3 | -14/+94 | |
state and one that is in non-dormant state. + Increased the priority of the Init task to force the dummy tasks to run first. + Added calls to ref_tsk to verify the state of the dummy tasks and test ref_tsk. | |||||
1999-11-12 | + Modified calls to use TSK_SLF for calls to self. | Joel Sherrill | 1 | -25/+24 | |
+ Modified calls to use the task id macro for calls to the PREEMPT task. | |||||
1999-11-12 | + Added comments on paths tested. | Joel Sherrill | 2 | -1/+14 | |
1999-11-12 | + Added check for priority over 256. | Joel Sherrill | 1 | -1/+4 | |
+ Modified output to correctly state the error. | |||||
1999-11-12 | Added comments for path's tested. | Joel Sherrill | 1 | -0/+3 | |
1999-11-12 | Test name changed to reflect placement after merger. | Joel Sherrill | 6 | -8/+9 | |
1999-11-12 | Test name changed to reflect placement after merger. | Joel Sherrill | 2 | -6/+11 | |
Changed output to reflect what was actually being tested. | |||||
1999-11-12 | Test name changed to reflect placement after merger. | Joel Sherrill | 4 | -5/+9 | |
Increased stack space. | |||||
1999-11-12 | Enabled after merging message buffer code. | Joel Sherrill | 1 | -6/+2 | |
1999-11-10 | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 15 | -22/+81 | |
prints a message instead of actually testing since the message buffer implementation is not in yet. | |||||
1999-11-10 | Combination of committing some new files which had been overlooked | Joel Sherrill | 5 | -1/+95 | |
and adding code which installed screens for itron tests. | |||||
1999-11-09 | Added more tasking tests. | Joel Sherrill | 1 | -1/+2 | |
1999-11-09 | Merged tests from Task group. | Joel Sherrill | 30 | -38/+1553 | |
1999-11-09 | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 10 | -0/+969 | |
for RTEMS. |
