2010-06-17 | Remove (Abandoned) | Ralf Corsepius | 1 | -47/+0 | |
2009-10-30 | Add missing prototypes. | Ralf Corsepius | 1 | -5/+5 | |
2004-04-01 | * itronhello/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. | Ralf Corsepius | 1 | -1/+1 | |
* itronmbf01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itronmbox01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itrontask01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itrontask02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itrontask03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itrontask04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * itrontime01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. | |||||
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* itronhello/system.h: Include <rtems/itron.h> instead of <itron.h>. * itronmbf01/system.h: Include <rtems/itron.h> instead of <itron.h>. * itronmbox01/system.h: Include <rtems/itron.h> instead of <itron.h>. * itronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>. * itrontask01/system.h: Include <rtems/itron.h> instead of <itron.h>. * itrontask02/system.h: Include <rtems/itron.h> instead of <itron.h>. * itrontask03/system.h: Include <rtems/itron.h> instead of <itron.h>. * itrontask04/system.h: Include <rtems/itron.h> instead of <itron.h>. * itrontime01/system.h: Include <rtems/itron.h> instead of <itron.h>. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* itronhello/init.c, itronhello/itronhello.doc, itronhello/system.h, itronmbf01/init.c, itronmbf01/itronmbf01.doc, itronmbf01/system.h, itronmbox01/init.c, itronmbox01/system.h, itronsem01/init.c, itronsem01/itronsem01.doc, itronsem01/system.h, itrontask01/init.c, itrontask01/itrontask01.doc, itrontask01/system.h, itrontask01/task1.c, itrontask02/dormant.c, itrontask02/init.c, itrontask02/itrontask02.doc, itrontask02/system.h, itrontask03/init.c, itrontask03/itrontask03.doc, itrontask03/preempt.c, itrontask03/system.h, itrontask03/task1.c, itrontask03/task2.c, itrontask03/task3.c, itrontask04/init.c, itrontask04/itrontask04.doc, itrontask04/system.h, itrontask04/task1.c, itrontask04/task2.c, itrontask04/task3.c, itrontime01/init.c, itrontime01/system.h: URL for license changed. | |||||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 1 | -2/+5 | |
1999-11-17 | + Updated copyright information. | Jennifer Averett | 1 | -2/+1 | |
1999-11-10 | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1 | -0/+1 | |
prints a message instead of actually testing since the message buffer implementation is not in yet. | |||||
1999-11-09 | Merged tests from Task group. | Joel Sherrill | 1 | -2/+9 | |
1999-11-09 | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1 | -4/+4 | |
for RTEMS. | |||||
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 1 | -1/+1 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1 | -2/+2 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1 | -5/+5 | |
of switching to the modified GNU GPL. | |||||
1996-05-29 | tests now specify whether using posix initialization threads table | Joel Sherrill | 1 | -0/+2 | |
or rtems initialization table in configuration table | |||||
1995-09-11 | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1 | -8/+11 | |
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | |||||
1995-08-23 | Support for variable length names added to Object Handler. This supports | Joel Sherrill | 1 | -1/+1 | |
both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested. | |||||
1995-08-17 | maximum number of messages removed and include statement cleanup | Joel Sherrill | 1 | -2/+4 | |
