* | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * itronhello/init.c, itronmbf01/init.c, itronmbox01/init.c, itronsem01/init.c, itrontask01/task1.c, itrontask02/init.c, itrontask03/task1.c, itrontask04/task3.c, itrontime01/init.c: Modified. | ||||
* | Fixed warnings. | Joel Sherrill | 2000-01-04 | 1 | -1/+0 |
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 1 | -2/+1 |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 1 | -1/+1 |
* | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1999-11-10 | 1 | -1/+1 |
| | | | | | prints a message instead of actually testing since the message buffer implementation is not in yet. | ||||
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 1 | -0/+59 |
