* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 2 | -6/+8 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | Uncommitted remains of a previous patch from Ralf Corsepius | Joel Sherrill | 1999-11-30 | 1 | -0/+43 |
| | | | | <corsepiu@faw.uni-ulm.de> which converted fiels to automake. | ||||
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 4 | -6/+6 |
* | Added test case of rsm_tsk and frsm_tsk on a task not suspended. | Jennifer Averett | 1999-11-16 | 2 | -3/+14 |
| | | | | This should result in nothing happening, but an E_OK result. | ||||
* | Updated scn file to match new output. Left out unemplemented | Jennifer Averett | 1999-11-16 | 1 | -17/+12 |
| | | | | parts as a reminder to fix when these routines became implemented. | ||||
* | + Changed ID to 1. ( Compilation error introduced by modifications. ) | Jennifer Averett | 1999-11-16 | 1 | -1/+1 |
* | Changed to call tmmacros instead of assert. | Jennifer Averett | 1999-11-16 | 1 | -141/+153 |
* | + Changed preempt routine into two dummy tasks one that is in dormant | Jennifer Averett | 1999-11-15 | 3 | -14/+94 |
| | | | | | | | | state and one that is in non-dormant state. + Increased the priority of the Init task to force the dummy tasks to run first. + Added calls to ref_tsk to verify the state of the dummy tasks and test ref_tsk. | ||||
* | + Modified calls to use TSK_SLF for calls to self. | Joel Sherrill | 1999-11-12 | 1 | -25/+24 |
| | | | | + Modified calls to use the task id macro for calls to the PREEMPT task. | ||||
* | + Added check for priority over 256. | Joel Sherrill | 1999-11-12 | 1 | -1/+4 |
| | | | | + Modified output to correctly state the error. | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 2 | -6/+11 |
| | | | | Changed output to reflect what was actually being tested. | ||||
* | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1999-11-10 | 2 | -1/+16 |
| | | | | | prints a message instead of actually testing since the message buffer implementation is not in yet. | ||||
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 4 | -0/+662 |
