* itronmbf01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itronmbox01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontime01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itronhello/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itronmbf01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itronmbox01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask02/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask03/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask04/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontime01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itronhello/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* itronmbf01/Makefile.am: Ditto.
* itronmbox01/Makefile.am: Ditto.
* itronsem01/Makefile.am: Ditto.
* itrontask01/Makefile.am: Ditto.
* itrontask02/Makefile.am: Ditto.
* itrontask03/Makefile.am: Ditto.
* itrontask04/Makefile.am: Ditto.
* itrontime01/Makefile.am: Ditto.
* itronhello/Makefile.am: Remove all-local: $(ARCH).
* itronmbf01/Makefile.am: Remove all-local: $(ARCH).
* itronmbox01/Makefile.am: Remove all-local: $(ARCH).
* itronsem01/Makefile.am: Remove all-local: $(ARCH).
* itrontask01/Makefile.am: Remove all-local: $(ARCH).
* itrontask02/Makefile.am: Remove all-local: $(ARCH).
* itrontask03/Makefile.am: Remove all-local: $(ARCH).
* itrontask04/Makefile.am: Remove all-local: $(ARCH).
* itrontime01/Makefile.am: Remove all-local: $(ARCH).
* itronhello/init.c, itronhello/itronhello.doc, itronhello/system.h,
itronmbf01/init.c, itronmbf01/itronmbf01.doc, itronmbf01/system.h,
itronmbox01/init.c, itronmbox01/system.h, itronsem01/init.c,
itronsem01/itronsem01.doc, itronsem01/system.h, itrontask01/init.c,
itrontask01/itrontask01.doc, itrontask01/system.h,
itrontask01/task1.c, itrontask02/dormant.c, itrontask02/init.c,
itrontask02/itrontask02.doc, itrontask02/system.h,
itrontask03/init.c, itrontask03/itrontask03.doc,
itrontask03/preempt.c, itrontask03/system.h, itrontask03/task1.c,
itrontask03/task2.c, itrontask03/task3.c, itrontask04/init.c,
itrontask04/itrontask04.doc, itrontask04/system.h,
itrontask04/task1.c, itrontask04/task2.c, itrontask04/task3.c,
itrontime01/init.c, itrontime01/system.h: URL for license changed.
itronhello/Makefile.am: Reflect having moved automake.
itronmbf01/Makefile.am: Reflect having moved automake.
itronmbox01/Makefile.am: Reflect having moved automake.
itronsem01/Makefile.am: Reflect having moved automake.
itrontask01/Makefile.am: Reflect having moved automake.
itrontask02/Makefile.am: Reflect having moved automake.
itrontask03/Makefile.am: Reflect having moved automake.
itrontask04/Makefile.am: Reflect having moved automake.
itrontime01/Makefile.am: Reflect having moved automake.
* itronhello/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronmbf01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronmbox01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask02/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask03/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask04/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontime01/Makefile.am: Use .$(OBJEXT) instead of .o.
enable this support.
* itronhello/init.c, itronmbf01/init.c, itronmbox01/init.c,
itronsem01/init.c, itrontask01/task1.c, itrontask02/init.c,
itrontask03/task1.c, itrontask04/task3.c, itrontime01/init.c: Modified.
* itronhello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbf01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbox01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontime01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask03/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask04/Makefile.am: include leaf.am instead of leaf.cfg.
* itronmbf01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronhello/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontime01/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask01/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask02/Makefile.am: include leaf.am instead of leaf.cfg.
* itronmbox01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am: Include compile.am
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
This should result in nothing happening, but an E_OK result.
parts as a reminder to fix when these routines became implemented.
state and one that is in non-dormant state.
+ Increased the priority of the Init task to force the dummy tasks to
run first.
+ Added calls to ref_tsk to verify the state of the dummy tasks and
test ref_tsk.
+ Modified calls to use the task id macro for calls to the PREEMPT task.
+ Modified output to correctly state the error.
Changed output to reflect what was actually being tested.
prints a message instead of actually testing since the message buffer
implementation is not in yet.
