* itronhello/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronmbf01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronmbox01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itronsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask01/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask02/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask03/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontask04/Makefile.am: Use .$(OBJEXT) instead of .o.
* itrontime01/Makefile.am: Use .$(OBJEXT) instead of .o.
enable this support.
* itronhello/init.c, itronmbf01/init.c, itronmbox01/init.c,
itronsem01/init.c, itrontask01/task1.c, itrontask02/init.c,
itrontask03/task1.c, itrontask04/task3.c, itrontime01/init.c: Modified.
* itronhello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbf01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbox01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontime01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask03/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask04/Makefile.am: include leaf.am instead of leaf.cfg.
* itronmbf01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronhello/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontime01/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask01/Makefile.am: include leaf.am instead of leaf.cfg.
* itrontask02/Makefile.am: include leaf.am instead of leaf.cfg.
* itronmbox01/Makefile.am: include leaf.am instead of leaf.cfg.
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am: Include compile.am
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
prints a message instead of actually testing since the message buffer
implementation is not in yet.
for RTEMS.
