* Makefile.am: Cleanup.
itronhello/Makefile.am: Reflect having moved automake.
itronmbf01/Makefile.am: Reflect having moved automake.
itronmbox01/Makefile.am: Reflect having moved automake.
itronsem01/Makefile.am: Reflect having moved automake.
itrontask01/Makefile.am: Reflect having moved automake.
itrontask02/Makefile.am: Reflect having moved automake.
itrontask03/Makefile.am: Reflect having moved automake.
itrontask04/Makefile.am: Reflect having moved automake.
itrontime01/Makefile.am: Reflect having moved automake.
* itronhello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbf01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronmbox01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontask04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontime01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* itrontests.am: Remove DEFS.
Addtional major bugs:
prints a message instead of actually testing since the message buffer
implementation is not in yet.
and adding code which installed screens for itron tests.
for RTEMS.
