updates 1394
Rename CONFIGURE_IMFS_DISABLE_FCHMOD to CONFIGURE_IMFS_DISABLE_CHMOD.
Resurrect CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM.
Remove miniIMFS. Statically initialize the root IMFS.
Add configuration options to disable individual
features of the root IMFS, e.g.
o CONFIGURE_IMFS_DISABLE_CHOWN,
o CONFIGURE_IMFS_DISABLE_FCHMOD,
o CONFIGURE_IMFS_DISABLE_LINK,
o CONFIGURE_IMFS_DISABLE_MKNOD,
o CONFIGURE_IMFS_DISABLE_MOUNT,
o CONFIGURE_IMFS_DISABLE_READLINK,
o CONFIGURE_IMFS_DISABLE_RENAME,
o CONFIGURE_IMFS_DISABLE_RMNOD,
o CONFIGURE_IMFS_DISABLE_SYMLINK,
o CONFIGURE_IMFS_DISABLE_UNMOUNT, and
o CONFIGURE_IMFS_DISABLE_UTIME.
Fix memory leak in IMFS_fsunmount().
Drop IMFS_node_control::node_size field and add node_size parameter to
IMFS_allocate_node() and IMFS_create_node(). This reduces the size of
generic nodes.
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
Use the fstat handler instead.
This reverts commit bdcf4102f71d1bc2a50f23d2d425d85c24ec0900.
Avoid NULL pointer access in IMFS_is_imfs_instance(). File systems
mounted via mount() always have a valid type string.
Provide a file per BSP to list tests that do not build for a BSP. This change
removes the BSP_SMALL_MEMORY hack from the code. That hack was a
mistake.
Provide configuration files for each BSP with tests that cannot build.
Use snprintf() instead of sprintf(). Include missing header files.
Fix file system names. Remove superfluous defines.
This patch is a newer version of the test presented on
http://www.rtems.org/pipermail/rtems-devel/2014-February/005318.html
Unchecked error cases:
- EIO (physical error)
- ENOSPC (no space left in the new filepath)
- EROFS (already covered on testsuites/fstests/fsrofs01)
Untested functionality:
- File system lock during rename() operation
- If after rename() the link count of a file becomes 0 it should be
removed and the space ocupied by the file shall be freed and no longer
accessible (the function statvfs() gives "not implemented" on the imfs
file system, so this is postponed for now)
The readv() and writev() support was implemented in terms of multiple
calls to the read and write handlers. This imposes a problem on device
files which use an IO vector as single request entity. For example a
low-level network device (e.g. BPF(4)) may use an IO vector to create
one frame from multiple protocol layers each with its own IO vector
entry.
The FAT file system is not conformant with the POSIX requirements.
ftruncate() and open() with O_TRUNC shall upon successful completion
mark for update the st_ctime and st_mtime fields of the file.
truncate() shall upon successful completion, if the file size is
changed, mark for update the st_ctime and st_mtime fields of the file.
The POSIX standard "The Open Group Base Specifications Issue 7", IEEE
Std 1003.1, 2013 Edition says nothing about the behaviour of truncate()
if the file size remains unchanged.
Future directions of the standard may mandate the behaviour specified in
ftruncate():
http://austingroupbugs.net/view.php?id=489
The open path should update the times even if the truncate does not
change the size.
Test handling of file names and directory names according to Microsofts
specification for the FAT file system. Tests for compatibility with a
genuine MS Windows FAT file system have been added.
Test handling of file names and directory names according to Microsofts specification
for the FAT file system. Tests for multibyte file names and directory names have been added.
specification for the FAT file system. So far tested only for the
default character set (code page 850).
