* | Revert "fstests/mdosfs_fstime: Remove test" | Sebastian Huber | 2014-10-23 | 3 | -0/+35 |
| | | | | This reverts commit bdcf4102f71d1bc2a50f23d2d425d85c24ec0900. | ||||
* | IMFS: Avoid NULL pointer access | Sebastian Huber | 2014-10-08 | 1 | -0/+11 |
| | | | | | Avoid NULL pointer access in IMFS_is_imfs_instance(). File systems mounted via mount() always have a valid type string. | ||||
* | testsuites: Remove BSP_SMALL_MEMORY | Joel Sherrill | 2014-05-06 | 2 | -33/+13 |
* | testsuite: Add a per BSP test check for tests not to build. | Chris Johns | 2014-05-05 | 1 | -45/+45 |
| | | | | | | | | Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build. | ||||
* | fsdosfsname01: Honor BSP_SMALL_MEMORY | Joel Sherrill | 2014-04-22 | 1 | -9/+23 |
* | fsdosfsformat01: Honor BSP_SMALL_MEMORY | Joel Sherrill | 2014-04-22 | 1 | -4/+10 |
* | privateenv: Use POSIX keys instead of task variables. | Christian Mauderer | 2014-03-27 | 5 | -0/+6 |
* | privateenv: Remove sharing of user environment between threads. | Christian Mauderer | 2014-03-27 | 2 | -13/+0 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 52 | -52/+52 |
* | fstests/fsrename: Fix stack corruption | Sebastian Huber | 2014-03-20 | 2 | -30/+56 |
| | | | | Use snprintf() instead of sprintf(). Include missing header files. | ||||
* | tests/fstests: Remove duplicate begin/end messages | Sebastian Huber | 2014-03-20 | 12 | -31/+7 |
| | | | | Fix file system names. Remove superfluous defines. | ||||
* | New fstest to check rename POSIX conformance | Andre Marques | 2014-03-17 | 6 | -0/+1546 |
| | | | | | | | | | | | | | | | | | | | | | | | This patch is a newer version of the test presented on http://www.rtems.org/pipermail/rtems-devel/2014-February/005318.html Unchecked error cases: - EIO (physical error) - ENOSPC (no space left in the new filepath) - EROFS (already covered on testsuites/fstests/fsrofs01) Untested functionality: - File system lock during rename() operation - If after rename() the link count of a file becomes 0 it should be removed and the space ocupied by the file shall be freed and no longer accessible (the function statvfs() gives "not implemented" on the imfs file system, so this is postponed for now) | ||||
* | tests/fstests: Use <rtems/test.h> | Sebastian Huber | 2014-03-17 | 25 | -31/+99 |
* | fstests and libtests: Add contents to multiple documentation files | Cynthia Rempel | 2014-01-08 | 2 | -7/+74 |
* | fsdosfsformat01.doc: Add contents | Cynthia Rempel | 2014-01-07 | 1 | -4/+18 |
* | fsbdpart01.doc: Add contents | Cynthia Rempel | 2014-01-07 | 1 | -4/+21 |
* | Filesystem: Add readv/writev handlers | Sebastian Huber | 2013-12-20 | 1 | -2/+47 |
| | | | | | | | | | The readv() and writev() support was implemented in terms of multiple calls to the read and write handlers. This imposes a problem on device files which use an IO vector as single request entity. For example a low-level network device (e.g. BPF(4)) may use an IO vector to create one frame from multiple protocol layers each with its own IO vector entry. | ||||
* | Misc tests: Fix scn files and adjust output | Joel Sherrill | 2013-11-18 | 1 | -0/+2 |
* | testsuites: Add missing .scn files | Joel Sherrill | 2013-11-15 | 42 | -20/+1040 |
* | Rename imfs_fspathenval.scn to imfs_fspatheval.scn | Joel Sherrill | 2013-11-15 | 2 | -2/+1 |
* | fsdosfsname01: Improve test for duplicate names | Ralf Kirchner | 2013-11-15 | 1 | -1/+9 |
* | fsdosfsformat01: Add test for re-mount of a filesystem | Ralf Kirchner | 2013-10-18 | 1 | -0/+11 |
* | JFFS2: New tests | Sebastian Huber | 2013-09-19 | 11 | -0/+411 |
* | fstests/mdosfs_fstime: Remove test | Sebastian Huber | 2013-09-16 | 3 | -35/+0 |
| | | | | The FAT file system is not conformant with the POSIX requirements. | ||||
* | fstests/fstime: Fix according to POSIX | Sebastian Huber | 2013-09-13 | 1 | -102/+139 |
| | | | | | | | | | | | | | | | | | ftruncate() and open() with O_TRUNC shall upon successful completion mark for update the st_ctime and st_mtime fields of the file. truncate() shall upon successful completion, if the file size is changed, mark for update the st_ctime and st_mtime fields of the file. The POSIX standard "The Open Group Base Specifications Issue 7", IEEE Std 1003.1, 2013 Edition says nothing about the behaviour of truncate() if the file size remains unchanged. Future directions of the standard may mandate the behaviour specified in ftruncate(): http://austingroupbugs.net/view.php?id=489 | ||||
* | fstests/fspermission: Fix resource leak | Sebastian Huber | 2013-09-13 | 1 | -2/+9 |
* | Check times with a no change truncate via open. | Chris Johns | 2013-08-08 | 1 | -1/+31 |
| | | | | | The open path should update the times even if the truncate does not change the size. | ||||
* | fsdsosfsname01: Ensure endian correctness | Ralf Kirchner | 2013-06-03 | 3 | -33/+6418 |
* | fsdosfsname01: Add compatibility tests | Ralf Kirchner | 2013-06-03 | 6 | -0/+11294 |
| | | | | | | Test handling of file names and directory names according to Microsofts specification for the FAT file system. Tests for compatibility with a genuine MS Windows FAT file system have been added. | ||||
* | fsdosfsname01: Add multibyte tests | Ralf Kirchner | 2013-06-03 | 2 | -1/+286 |
| | | | | | Test handling of file names and directory names according to Microsofts specification for the FAT file system. Tests for multibyte file names and directory names have been added. | ||||
* | fsdosfsname01: New test | Ralf Kirchner | 2013-06-03 | 6 | -0/+688 |
| | | | | | | Test handling of file names and directory names according to Microsofts specification for the FAT file system. So far tested only for the default character set (code page 850). | ||||
* | dosfs: Add RTEMS_DOSFS_SEMAPHORES_PER_INSTANCE | Ralf Kirchner | 2013-05-24 | 1 | -0/+1 |
* | fstests: Use "tmacros.h" instead of "pmacros.h" | Ralf Kirchner | 2013-05-24 | 1 | -1/+1 |
* | fstests/fsstatvfs: Fix end of test message | Sebastian Huber | 2013-05-16 | 1 | -1/+1 |
* | dosfs: Add statvfs() support | Andrei Mozzhuhin | 2013-05-16 | 5 | -0/+141 |
* | testsuites: Fix warnings | Sebastian Huber | 2013-04-11 | 2 | -1/+4 |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 1 | -313/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | libblock: Do resource allocation in one place | Sebastian Huber | 2013-02-21 | 2 | -33/+0 |
| | | | | | | | All resource allocations take place in rtems_bdbuf_init() now. After rtems_bdbuf_init() no fatal errors can happen due to configuration errors or resource limits. This makes it easier to detect configuration errors for users. | ||||
* | fstests/fsrdwr: Add test case | Sebastian Huber | 2013-02-20 | 3 | -1/+59 |
* | fstests/fsrdwr: Fix warning | Sebastian Huber | 2013-02-20 | 1 | -1/+1 |
* | fstests: Prevent compiler optimizations | Sebastian Huber | 2013-02-15 | 1 | -1/+4 |
* | fstests/fsrdwr: Free allocated memory | Sebastian Huber | 2013-01-30 | 1 | -0/+4 |
* | fstests: Check resources used by FAT file system | Sebastian Huber | 2013-01-30 | 1 | -0/+6 |
* | fstests: Use global environment and clean up | Sebastian Huber | 2013-01-30 | 1 | -3/+14 |
| | | | | This releases all resources acquired by the chroot(). | ||||
* | fstests: Initialize swapout task | Sebastian Huber | 2013-01-30 | 1 | -0/+19 |
* | fstests: Perform a quick format | Sebastian Huber | 2013-01-30 | 1 | -1/+1 |
* | fstests: Use designated initializers | Sebastian Huber | 2013-01-30 | 1 | -10/+10 |
* | fstests: Generating .scn (Screen Shots) #4 | Alex Ivanov | 2013-01-15 | 6 | -0/+192 |
* | IMFS: Generating .scn (Screen Shots) #2 | Christopher Kerl | 2013-01-02 | 6 | -0/+276 |
* | libblock: Use rtems_blkdev_create_partition() | Sebastian Huber | 2012-12-21 | 1 | -2/+26 |
| | | | | | Use rtems_blkdev_create_partition() instead of rtems_disk_create_log() to avoid problems with the huge IMFS_GENERIC_DEVICE_MAJOR_NUMBER. |
