Do not use our long file name entry count to optimize the file name
search. The Unicode comparison must be taken into account.
Update #2939.
Remove forced overwrite which leads to file data corruption. The logic
to determine a forced overwrite was fundamentally broken. For simplity,
disable this feature.
Update #2622.
It is all right in case the result uses the full destination buffer.
Without this fix the handling of a maximum 8.3 short file name is
broken.
Update #2928.
Perform a context-dependent deferred location release to avoid a
deadlock on the file system instance locks, for example during a
chdir().
Update #2936.
For a filename match the entry must match without anything remaining.
Close #2908.
Update #1394.
Update #2844.
Add IO control to force a garbage collection.
Update #2844.
Add IO control RTEMS_JFFS2_GET_INFO to get some JFFS2 filesystem
instance information.
Update #2844.
This avoids problems with console drivers that require a more complete
IMFS.
of this patch set.
Update #2408.
The permission is check by the upper layer.
In case the zlib compression was used, then the librtemscpu.a depended
on libz.a. To avoid a GCC patch or complicated link flags move the
JFFS2 support into a separate library to use a simple "-ljffs2 -lz" to
link the executable.
Close #2317.
updates 1394
Rename CONFIGURE_IMFS_DISABLE_FCHMOD to CONFIGURE_IMFS_DISABLE_CHMOD.
Resurrect CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM.
Remove miniIMFS. Statically initialize the root IMFS.
Add configuration options to disable individual
features of the root IMFS, e.g.
o CONFIGURE_IMFS_DISABLE_CHOWN,
o CONFIGURE_IMFS_DISABLE_FCHMOD,
o CONFIGURE_IMFS_DISABLE_LINK,
o CONFIGURE_IMFS_DISABLE_MKNOD,
o CONFIGURE_IMFS_DISABLE_MOUNT,
o CONFIGURE_IMFS_DISABLE_READLINK,
o CONFIGURE_IMFS_DISABLE_RENAME,
o CONFIGURE_IMFS_DISABLE_RMNOD,
o CONFIGURE_IMFS_DISABLE_SYMLINK,
o CONFIGURE_IMFS_DISABLE_UNMOUNT, and
o CONFIGURE_IMFS_DISABLE_UTIME.
Fix memory leak in IMFS_fsunmount().
Drop IMFS_node_control::node_size field and add node_size parameter to
IMFS_allocate_node() and IMFS_create_node(). This reduces the size of
generic nodes.
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
Use the fstat handler instead.
This reverts commit bdcf4102f71d1bc2a50f23d2d425d85c24ec0900.
Avoid NULL pointer access in IMFS_is_imfs_instance(). File systems
mounted via mount() always have a valid type string.
Provide a file per BSP to list tests that do not build for a BSP. This change
removes the BSP_SMALL_MEMORY hack from the code. That hack was a
mistake.
Provide configuration files for each BSP with tests that cannot build.
Use snprintf() instead of sprintf(). Include missing header files.
Fix file system names. Remove superfluous defines.
This patch is a newer version of the test presented on
http://www.rtems.org/pipermail/rtems-devel/2014-February/005318.html
Unchecked error cases:
- EIO (physical error)
- ENOSPC (no space left in the new filepath)
- EROFS (already covered on testsuites/fstests/fsrofs01)
Untested functionality:
- File system lock during rename() operation
- If after rename() the link count of a file becomes 0 it should be
removed and the space ocupied by the file shall be freed and no longer
accessible (the function statvfs() gives "not implemented" on the imfs
file system, so this is postponed for now)
The readv() and writev() support was implemented in terms of multiple
calls to the read and write handlers. This imposes a problem on device
files which use an IO vector as single request entity. For example a
low-level network device (e.g. BPF(4)) may use an IO vector to create
one frame from multiple protocol layers each with its own IO vector
entry.
