Update #3409.
upgrade to that version.
Close #3387.
Add tests to check the patches for this ticket exist and are fixed.
Close #3089
Update #3382
Update #1971.
The tmpfile() uses sprintf().
Update #1971.
Close #1971.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
The fstests use snprintf().
If there is already a file with a long file name it isn't possible to
create a second file which has a name that ends on the first files name
(for example ets.beam and sets.beam). This patch fixes that.
Update #3258.
Take care that a file in the root directory with the same name as the
volume name can be found.
Update #3257.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #3136.
Check iop reference count in close() and return -1 with errno set to
EBUSY in case the file descriptor is still in use.
Update #3132.
Close #3003.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
Do not use our long file name entry count to optimize the file name
search. The Unicode comparison must be taken into account.
Update #2939.
Remove forced overwrite which leads to file data corruption. The logic
to determine a forced overwrite was fundamentally broken. For simplity,
disable this feature.
Update #2622.
It is all right in case the result uses the full destination buffer.
Without this fix the handling of a maximum 8.3 short file name is
broken.
Update #2928.
Perform a context-dependent deferred location release to avoid a
deadlock on the file system instance locks, for example during a
chdir().
Update #2936.
For a filename match the entry must match without anything remaining.
Close #2908.
Update #1394.
Update #2844.
Add IO control to force a garbage collection.
Update #2844.
Add IO control RTEMS_JFFS2_GET_INFO to get some JFFS2 filesystem
instance information.
Update #2844.
This avoids problems with console drivers that require a more complete
IMFS.
of this patch set.
Update #2408.
The permission is check by the upper layer.
In case the zlib compression was used, then the librtemscpu.a depended
on libz.a. To avoid a GCC patch or complicated link flags move the
JFFS2 support into a separate library to use a simple "-ljffs2 -lz" to
link the executable.
Close #2317.
updates 1394
Rename CONFIGURE_IMFS_DISABLE_FCHMOD to CONFIGURE_IMFS_DISABLE_CHMOD.
Resurrect CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM.
Remove miniIMFS. Statically initialize the root IMFS.
Add configuration options to disable individual
features of the root IMFS, e.g.
o CONFIGURE_IMFS_DISABLE_CHOWN,
o CONFIGURE_IMFS_DISABLE_FCHMOD,
o CONFIGURE_IMFS_DISABLE_LINK,
o CONFIGURE_IMFS_DISABLE_MKNOD,
o CONFIGURE_IMFS_DISABLE_MOUNT,
o CONFIGURE_IMFS_DISABLE_READLINK,
o CONFIGURE_IMFS_DISABLE_RENAME,
o CONFIGURE_IMFS_DISABLE_RMNOD,
o CONFIGURE_IMFS_DISABLE_SYMLINK,
o CONFIGURE_IMFS_DISABLE_UNMOUNT, and
o CONFIGURE_IMFS_DISABLE_UTIME.
