This reverts commit cf42a6ea9dbb6ebee498ae8db319d3e475bcd6be.
This allows addtion of per disk statistics for example.
The scope of the file system operations is the file system instance.
The scope of the file system node handlers is the file location. The
benefit of moving the operations to the mount table entry is a size
reduction of the file location (rtems_filesystem_location_info_t). The
code size is slightly increased due to additional load instructions.
Restructure rtems_filesystem_mount_table_entry_t to improve cache
efficiency.
The fat_file_datasync() read every cluster of the file into the cache
and then synchronized it step-by-step. For unmodified buffers this is a
non-operation. For modified buffers this will wake-up the swapout task
which performs then a single buffer write operation. This is usually
quite inefficient. Firstly we do single buffer writes, secondly we
may perform a lot of unnecessary read operations (for huge files this is
really bad), and thirdly this leads likely to cache evictions.
The synchronization procedure is replaced by a simple
rtems_bdbuf_sync_dev(). This has the side-effect that also buffers not
related to the file are synchronized, but since the modified list is
normally short this should be acceptable.
According to POSIX the lseek() function shall not, by itself, extend the
size of a file.
Remove the size field of rtems_libio_t. A file has only one size but
may have multiple open file descriptors. Thus a file size field in the
file descriptor may lead to inconsistencies.
New default handlers rtems_filesystem_default_lseek_file() and
rtems_filesystem_default_lseek_directory().
for details.
Generic nodes are an alternative to standard drivers in RTEMS. The
handlers of a generic node are called with less overhead compared to the
standard driver operations. The usage of file system node handlers
enable more features like support for fsync() and fdatasync(). The
generic nodes use the reference counting of the IMFS. This provides
automatic node destruction when the last reference vanishes.
Extend type IMFS_types_union by new type IMFS_generic_t.
Extend enum IMFS_jnode_types_t by IMFS_GENERIC.
Add functions
o IMFS_make_generic_node(),
o IMFS_is_imfs_instance(),
o IMFS_generic_get_context_by_node(),
o IMFS_generic_get_context_by_location(), and
o IMFS_generic_get_context_by_iop().
New test fstests/fsimfsgeneric01.
o Make sure EROFS is indicated for write operations on a read-only file
system.
o Add error indication for read-only file systems in fchmod() and
fchown() according to POSIX.
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
o Due to the usual integer propagation rules care must be taken in case
off_t is involved.
o Use the effective UID and GID consistently.
* imfs_support/fs_supprot.h: Remove (Unused).
PR 1589/build
* imfs_fserror/Makefile.am, imfs_fslink/Makefile.am,
imfs_fspatheval/Makefile.am, imfs_fspermission/Makefile.am,
imfs_fsrdwr/Makefile.am, imfs_fssymlink/Makefile.am,
imfs_fstime/Makefile.am, mdosfs_fserror/Makefile.am,
mdosfs_fspatheval/Makefile.am, mdosfs_fsrdwr/Makefile.am,
mdosfs_fstime/Makefile.am, mimfs_fserror/Makefile.am,
mimfs_fslink/Makefile.am, mimfs_fspatheval/Makefile.am,
mimfs_fspermission/Makefile.am, mimfs_fsrdwr/Makefile.am,
mimfs_fssymlink/Makefile.am, mimfs_fstime/Makefile.am,
mrfs_fserror/Makefile.am, mrfs_fslink/Makefile.am,
mrfs_fspatheval/Makefile.am, mrfs_fspermission/Makefile.am,
mrfs_fsrdwr/Makefile.am, mrfs_fssymlink/Makefile.am,
mrfs_fstime/Makefile.am: Remove obsolete optional manager capability.
* Makefile.am: Fix DIST_SUBDIRS.
Reformat.
Add support/fstest.h.
* mrfs_support/fs_support.c: Resolved name conflict that was causing a
compiler error.
* fsrdwr/init.c: Use %zd to print size_t.
* fserror/test.c, fslink/test.c, fspatheval/test.c,
fspermission/test.c, fsrdwr/init.c, fssymlink/test.c,
fstime/test.c, support/fstest_support.c, support/ramdisk_support.c:
Explicitly include "pmacros.h".
* support/fstest.h: Don't include "pmacros.h".
* imfs_support/fs_supprot.h, support/fstest.h,
support/ramdisk_support.h: Don't include config.h.
Add config-header support.
* support/fstest.h: Include "pmacros.h".
* fserror/fserror.doc, fserror/test.c, fslink/fslink.doc,
fslink/test.c, fspatheval/patheval.doc, fspatheval/test.c,
fspermission/fspermission.doc, fspermission/test.c,
fsrdwr/fsrdwr.doc, fsrdwr/init.c, fssymlink/fssymlink.doc,
fssymlink/test.c, fstime/fstime.doc, fstime/test.c,
imfs_support/fs_config.h, imfs_support/fs_support.c,
imfs_support/fs_supprot.h, mdosfs_support/fs_config.h,
mdosfs_support/fs_support.c, mimfs_support/fs_config.h,
mimfs_support/fs_support.c, mrfs_support/fs_config.h,
mrfs_support/fs_support.c, support/fstest.h,
support/fstest_support.c, support/fstest_support.h,
support/ramdisk_support.c, support/ramdisk_support.h:
Fix CVS-Ids.
* configure.ac, fserror/test.c, fslink/test.c, fspermission/test.c,
fsrdwr/init.c, fssymlink/test.c, fstime/test.c,
mdosfs_support/fs_config.h, mdosfs_support/fs_support.c,
support/fstest.h, support/fstest_support.c,
support/ramdisk_support.c, support/ramdisk_support.h: Perform first
phase of clean up.
* imfs_fslink/Makefile.am, imfs_fssymlink/Makefile.am,
mimfs_fslink/Makefile.am, mimfs_fssymlink/Makefile.am,
mrfs_fslink/Makefile.am, mrfs_fssymlink/Makefile.am,
mrfs_support/fs_config.h: Correcting from previous commit of
incorrect tarball.
* fserror/fserror.doc, fserror/test.c, fspatheval/patheval.doc,
fspatheval/test.c, fspermission/fspermission.doc,
fspermission/test.c, fsrdwr/fsrdwr.doc, fsrdwr/init.c,
fstime/fstime.doc, fstime/test.c, imfs_fserror/.cvsignore,
imfs_fserror/Makefile.am, imfs_fslink/.cvsignore,
imfs_fspatheval/.cvsignore, imfs_fspatheval/Makefile.am,
imfs_fspermission/.cvsignore, imfs_fspermission/Makefile.am,
imfs_fsrdwr/.cvsignore, imfs_fsrdwr/Makefile.am,
imfs_fssymlink/.cvsignore, imfs_fstime/.cvsignore,
imfs_fstime/Makefile.am, imfs_support/fs_supprot.h,
mdosfs_fserror/.cvsignore, mdosfs_fserror/Makefile.am,
mdosfs_fspatheval/.cvsignore, mdosfs_fspatheval/Makefile.am,
mdosfs_fsrdwr/.cvsignore, mdosfs_fsrdwr/Makefile.am,
mdosfs_fstime/.cvsignore, mdosfs_fstime/Makefile.am,
mimfs_fserror/.cvsignore, mimfs_fserror/Makefile.am,
mimfs_fslink/.cvsignore, mimfs_fspatheval/.cvsignore,
mimfs_fspatheval/Makefile.am, mimfs_fspermission/.cvsignore,
mimfs_fspermission/Makefile.am, mimfs_fsrdwr/.cvsignore,
mimfs_fsrdwr/Makefile.am, mimfs_fssymlink/.cvsignore,
mimfs_fstime/.cvsignore, mimfs_fstime/Makefile.am,
mrfs_fserror/.cvsignore, mrfs_fserror/Makefile.am,
mrfs_fslink/.cvsignore, mrfs_fspatheval/.cvsignore,
mrfs_fspatheval/Makefile.am, mrfs_fspermission/.cvsignore,
mrfs_fspermission/Makefile.am, mrfs_fsrdwr/.cvsignore,
mrfs_fsrdwr/Makefile.am, mrfs_fssymlink/.cvsignore,
mrfs_fstime/.cvsignore, mrfs_fstime/Makefile.am: New files.
* Makefile.am, configure.ac, fslink/fslink.doc, fslink/test.c,
fssymlink/test.c, imfs_fslink/Makefile.am,
imfs_fssymlink/Makefile.am, imfs_support/fs_config.h,
imfs_support/fs_support.c, mdosfs_support/fs_config.h,
mdosfs_support/fs_support.c, mimfs_fslink/Makefile.am,
mimfs_fssymlink/Makefile.am, mimfs_support/fs_config.h,
mimfs_support/fs_support.c, mrfs_fslink/Makefile.am,
mrfs_fssymlink/Makefile.am, mrfs_support/fs_config.h,
support/ramdisk_support.c, support/ramdisk_support.h: Submit correct
tarball of current work.
* fs01/init.c, fsfchx/fsfchx.doc, fsfchx/init.c, fsfile01/fsfile01.doc,
fsfile01/test.c, fsfile01/test_cat.c, fsfile01/test_extend.c,
fsfile01/test_write.c, fsfile02/fsfile02.doc, fsfile02/init.c,
fsfstest/fs-test.c, fsfstest/fsfstest.doc, fsimfs01/fsimfs01.doc,
fsimfs01/init.c, fsimfs02/fsimfs02.doc, fsimfs02/init.c,
fsmkdir/fsmkdir.doc, fsmkdir/test.c, fsopen/fsopen.doc,
fsopen/test.c, fsrdwrv/fsrdwrv.doc, fsrdwrv/test.c,
fsreaddir/fsreaddir.doc, fsreaddir/test.c, fsrename/fsrename.doc,
fsrename/test.c, fsrmdir/test.c, fsrwfile/fsrwfile.doc,
fsrwfile/init.c, fsstat/fsstat.doc, fsstat/test.c,
fstruncate/fstruncate.doc, fstruncate/test.c, imfs_fs01/.cvsignore,
imfs_fs01/Makefile.am, imfs_fs01/imfs_fs01.scn,
imfs_fsfchx/.cvsignore, imfs_fsfchx/Makefile.am,
imfs_fsfile01/.cvsignore, imfs_fsfile01/Makefile.am,
imfs_fsfile02/.cvsignore, imfs_fsfile02/Makefile.am,
imfs_fsfstest/.cvsignore, imfs_fsfstest/Makefile.am,
imfs_fsimfs01/.cvsignore, imfs_fsimfs01/Makefile.am,
imfs_fsimfs02/.cvsignore, imfs_fsimfs02/Makefile.am,
imfs_fslink/.cvsignore, imfs_fsmkdir/.cvsignore,
imfs_fsmkdir/Makefile.am, imfs_fsopen/.cvsignore,
imfs_fsopen/Makefile.am, imfs_fsrdwrv/.cvsignore,
imfs_fsrdwrv/Makefile.am, imfs_fsreaddir/.cvsignore,
imfs_fsreaddir/Makefile.am, imfs_fsrename/.cvsignore,
imfs_fsrename/Makefile.am, imfs_fsrmdir/.cvsignore,
imfs_fsrmdir/Makefile.am, imfs_fsrwfile/.cvsignore,
imfs_fsrwfile/Makefile.am, imfs_fsstat/.cvsignore,
imfs_fsstat/Makefile.am, imfs_fssymlink/.cvsignore,
imfs_fstruncate/.cvsignore, imfs_fstruncate/Makefile.am,
mdosfs_fsfchx/.cvsignore, mdosfs_fsfchx/Makefile.am,
mdosfs_fsfile01/.cvsignore, mdosfs_fsfile01/Makefile.am,
mdosfs_fsfile02/.cvsignore, mdosfs_fsfile02/Makefile.am,
mdosfs_fsfstest/.cvsignore, mdosfs_fsfstest/Makefile.am,
mdosfs_fsimfs01/.cvsignore, mdosfs_fsimfs01/Makefile.am,
mdosfs_fsimfs02/.cvsignore, mdosfs_fsimfs02/Makefile.am,
mdosfs_fslink/.cvsignore, mdosfs_fslink/Makefile.am,
mdosfs_fsmkdir/.cvsignore, mdosfs_fsmkdir/Makefile.am,
mdosfs_fsopen/.cvsignore, mdosfs_fsopen/Makefile.am,
mdosfs_fsrdwrv/.cvsignore, mdosfs_fsrdwrv/Makefile.am,
mdosfs_fsreaddir/.cvsignore, mdosfs_fsreaddir/Makefile.am,
mdosfs_fsrename/.cvsignore, mdosfs_fsrename/Makefile.am,
mdosfs_fsrmdir/.cvsignore, mdosfs_fsrmdir/Makefile.am,
mdosfs_fsrwfile/.cvsignore, mdosfs_fsrwfile/Makefile.am,
mdosfs_fsstat/.cvsignore, mdosfs_fsstat/Makefile.am,
mdosfs_fssymlink/.cvsignore, mdosfs_fssymlink/Makefile.am,
mdosfs_fstruncate/.cvsignore, mdosfs_fstruncate/Makefile.am,
mimfs_fs01/.cvsignore, mimfs_fs01/Makefile.am,
mimfs_fs01/mimfs_fs01.scn, mimfs_fsfchx/.cvsignore,
mimfs_fsfchx/Makefile.am, mimfs_fsfile01/.cvsignore,
mimfs_fsfile01/Makefile.am, mimfs_fsfile02/.cvsignore,
mimfs_fsfile02/Makefile.am, mimfs_fsfstest/.cvsignore,
mimfs_fsfstest/Makefile.am, mimfs_fsimfs01/.cvsignore,
mimfs_fsimfs01/Makefile.am, mimfs_fsimfs02/.cvsignore,
mimfs_fsimfs02/Makefile.am, mimfs_fslink/.cvsignore,
mimfs_fsmkdir/.cvsignore, mimfs_fsmkdir/Makefile.am,
mimfs_fsopen/.cvsignore, mimfs_fsopen/Makefile.am,
mimfs_fsrdwrv/.cvsignore, mimfs_fsrdwrv/Makefile.am,
mimfs_fsreaddir/.cvsignore, mimfs_fsreaddir/Makefile.am,
mimfs_fsrename/.cvsignore, mimfs_fsrename/Makefile.am,
mimfs_fsrmdir/.cvsignore, mimfs_fsrmdir/Makefile.am,
mimfs_fsrwfile/.cvsignore, mimfs_fsrwfile/Makefile.am,
mimfs_fsstat/.cvsignore, mimfs_fsstat/Makefile.am,
mimfs_fssymlink/.cvsignore, mimfs_fstruncate/.cvsignore,
mimfs_fstruncate/Makefile.am, mrfs_fsfchx/.cvsignore,
mrfs_fsfchx/Makefile.am, mrfs_fsfile01/.cvsignore,
mrfs_fsfile01/Makefile.am, mrfs_fsfile02/.cvsignore,
mrfs_fsfile02/Makefile.am, mrfs_fsfstest/.cvsignore,
mrfs_fsfstest/Makefile.am, mrfs_fsimfs01/.cvsignore,
mrfs_fsimfs01/Makefile.am, mrfs_fsimfs02/.cvsignore,
mrfs_fsimfs02/Makefile.am, mrfs_fslink/.cvsignore,
mrfs_fsmkdir/.cvsignore, mrfs_fsmkdir/Makefile.am,
mrfs_fsopen/.cvsignore, mrfs_fsopen/Makefile.am,
mrfs_fsrdwrv/.cvsignore, mrfs_fsrdwrv/Makefile.am,
mrfs_fsreaddir/.cvsignore, mrfs_fsreaddir/Makefile.am,
mrfs_fsrename/.cvsignore, mrfs_fsrename/Makefile.am,
mrfs_fsrmdir/.cvsignore, mrfs_fsrmdir/Makefile.am,
mrfs_fsrwfile/.cvsignore, mrfs_fsrwfile/Makefile.am,
mrfs_fsstat/.cvsignore, mrfs_fsstat/Makefile.am,
mrfs_fssymlink/.cvsignore, mrfs_fstruncate/.cvsignore,
mrfs_fstruncate/Makefile.am: Removed.
* Makefile.am, configure.ac, imfs_support/fs_config.h,
imfs_support/fs_support.c, mimfs_support/fs_config.h,
mimfs_support/fs_support.c: Add initial version of new filesystem
tests. There are multiple failures which need to be addressed by the
community.
* fsfchx/fsfchx.doc, fsfchx/init.c, fsfile01/fsfile01.doc,
fslink/fslink.doc, fslink/test.c, fsmkdir/fsmkdir.doc,
fsmkdir/test.c, fsopen/fsopen.doc, fsopen/test.c,
fsrdwrv/fsrdwrv.doc, fsrdwrv/test.c, fsreaddir/fsreaddir.doc,
fsreaddir/test.c, fsrename/fsrename.doc, fsrename/test.c,
fsrmdir/test.c, fsrwfile/fsrwfile.doc, fsrwfile/init.c,
fsstat/fsstat.doc, fsstat/test.c, fssymlink/fssymlink.doc,
fssymlink/test.c, fstruncate/fstruncate.doc, fstruncate/test.c,
imfs_fslink/.cvsignore, imfs_fslink/Makefile.am,
imfs_fsmkdir/.cvsignore, imfs_fsmkdir/Makefile.am,
imfs_fsopen/.cvsignore, imfs_fsopen/Makefile.am,
imfs_fsrdwrv/.cvsignore, imfs_fsrdwrv/Makefile.am,
imfs_fsreaddir/.cvsignore, imfs_fsreaddir/Makefile.am,
imfs_fsrename/.cvsignore, imfs_fsrename/Makefile.am,
imfs_fsrmdir/.cvsignore, imfs_fsrmdir/Makefile.am,
imfs_fsrwfile/.cvsignore, imfs_fsrwfile/Makefile.am,
imfs_fsstat/.cvsignore, imfs_fsstat/Makefile.am,
imfs_fssymlink/.cvsignore, imfs_fssymlink/Makefile.am,
mimfs_fsfchx/.cvsignore, mimfs_fsfchx/Makefile.am,
mimfs_fsfile01/.cvsignore, mimfs_fsfile01/Makefile.am,
mimfs_fsfile02/.cvsignore, mimfs_fsfile02/Makefile.am,
mimfs_fsfstest/.cvsignore, mimfs_fsfstest/Makefile.am,
mimfs_fsimfs01/.cvsignore, mimfs_fsimfs01/Makefile.am,
mimfs_fsimfs02/.cvsignore, mimfs_fsimfs02/Makefile.am,
mimfs_fslink/.cvsignore, mimfs_fslink/Makefile.am,
mimfs_fssymlink/.cvsignore, mimfs_fssymlink/Makefile.am,
mimfs_fstruncate/.cvsignore, mimfs_fstruncate/Makefile.am,
mrfs_fsfchx/.cvsignore, mrfs_fsfchx/Makefile.am,
mrfs_fsfile01/.cvsignore, mrfs_fsfile01/Makefile.am,
mrfs_fsfile02/.cvsignore, mrfs_fsfile02/Makefile.am,
mrfs_fsfstest/.cvsignore, mrfs_fsfstest/Makefile.am,
mrfs_fsimfs01/.cvsignore, mrfs_fsimfs01/Makefile.am,
mrfs_fsimfs02/.cvsignore, mrfs_fsimfs02/Makefile.am,
mrfs_fslink/.cvsignore, mrfs_fslink/Makefile.am,
mrfs_fssymlink/.cvsignore, mrfs_fssymlink/Makefile.am,
mrfs_fstruncate/.cvsignore, mrfs_fstruncate/Makefile.am,
mrfs_support/fs_config.h, mrfs_support/fs_support.c,
support/fstest.h, support/fstest_support.c, support/fstest_support.h,
support/ramdisk_support.c, support/ramdisk_support.h: New files.
* Makefile.am: Remove EXTRA_DIST.
* fs01/fs91.doc: Remove (Empty, unused).
* mimfs_fs01/Makefile.am: Use mimfs_support/fs_config.h.
Add initial test to File System Test Suite.
* .cvsignore, ChangeLog, Makefile.am, configure.ac, fs01/fs91.doc,
fs01/init.c, imfs_fs01/.cvsignore, imfs_fs01/Makefile.am,
imfs_fs01/imfs_fs01.scn, imfs_support/fs_config.h,
imfs_support/fs_support.c, mimfs_fs01/.cvsignore,
mimfs_fs01/Makefile.am, mimfs_fs01/mimfs_fs01.scn,
mimfs_support/fs_config.h, mimfs_support/fs_support.c: New files.
