This patch fixes a compiler warning:
../../../testsuites/fstests/fsdosfsname01/init.c:430:19: warning:
'%s' directive output may be truncated writing up to 6424 bytes into
a region of size 257 [-Wformat-truncation=]
The buffer 'dirname' is exactly large enough so that no truncation
can ever occur. Using the return value of snprintf() is an official
supported way to suppress the warning.
I considered the comment of Joel Sherrill about not replacing snprintf():
https://lists.rtems.org/pipermail/devel/2020-September/062113.html
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
There was a race conditon in the reference counting of file descriptors
during a close() operation. After the call to the close handler, the
rtems_libio_free() function cleared the flags to zero. However, at this
point in time there may still exist some holders of the file descriptor.
With RTEMS_DEBUG enabled this could lead to failed assertions in
rtems_libio_iop_drop().
Change the code to use only atomic read-modify-write operations on the
rtems_libio_iop::flags.
Update #3894.
The IO library used a POSIX key to store an optional POSIX user
environment pointer. This pulled in the POSIX keys support in every
application configuration. Add a user environment pointer to the thread
control block (TCB) instead. Applications which do not need the POSIX
user environment will just get an overhead of one pointer per thread.
Close #3882.
Update #3753.
This avoids an extra include path.
Update #3818.
Update #3358.
Remove use of TMPINSTALL_FILES.
Update #3358.
Update #3358.
This tool is now included in the RTEMS tools repository.
Close #3380.
Update #3409.
upgrade to that version.
Close #3387.
Add tests to check the patches for this ticket exist and are fixed.
Close #3089
Update #3382
Update #1971.
The tmpfile() uses sprintf().
Update #1971.
Close #1971.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
The fstests use snprintf().
If there is already a file with a long file name it isn't possible to
create a second file which has a name that ends on the first files name
(for example ets.beam and sets.beam). This patch fixes that.
Update #3258.
Take care that a file in the root directory with the same name as the
volume name can be found.
Update #3257.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #3136.
Check iop reference count in close() and return -1 with errno set to
EBUSY in case the file descriptor is still in use.
Update #3132.
Close #3003.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
Do not use our long file name entry count to optimize the file name
search. The Unicode comparison must be taken into account.
Update #2939.
Remove forced overwrite which leads to file data corruption. The logic
to determine a forced overwrite was fundamentally broken. For simplity,
disable this feature.
Update #2622.
It is all right in case the result uses the full destination buffer.
Without this fix the handling of a maximum 8.3 short file name is
broken.
Update #2928.
Perform a context-dependent deferred location release to avoid a
deadlock on the file system instance locks, for example during a
chdir().
Update #2936.
