Fix file system names. Remove superfluous defines.
Change block size of bdbuf to the cluster size if the data clusters are
aligned on a cluster boundary. This enables fast access to data
clusters.
Delete fattype parameter of msdos_format_request_param_t because the FAT
type is determined by cluster and disk size.
Estimate FAT type and re-evaluate FAT type after exact parameter
determination.
Add skip_alignment parameter of msdos_format_request_param_t. Delete
cluster_align parameter of msdos_format_request_param_t.
By default the FAT, data cluster, and root directory for FAT12 and FAT16
is aligned on a cluster boundary to optimize performance.
Format changes throughout.
o Due to the usual integer propagation rules care must be taken in case
off_t is involved.
o Use the effective UID and GID consistently.
* fserror/fserror.doc, fserror/test.c, fslink/fslink.doc,
fslink/test.c, fspatheval/patheval.doc, fspatheval/test.c,
fspermission/fspermission.doc, fspermission/test.c,
fsrdwr/fsrdwr.doc, fsrdwr/init.c, fssymlink/fssymlink.doc,
fssymlink/test.c, fstime/fstime.doc, fstime/test.c,
imfs_support/fs_config.h, imfs_support/fs_support.c,
imfs_support/fs_supprot.h, mdosfs_support/fs_config.h,
mdosfs_support/fs_support.c, mimfs_support/fs_config.h,
mimfs_support/fs_support.c, mrfs_support/fs_config.h,
mrfs_support/fs_support.c, support/fstest.h,
support/fstest_support.c, support/fstest_support.h,
support/ramdisk_support.c, support/ramdisk_support.h:
Fix CVS-Ids.
* configure.ac, fserror/test.c, fslink/test.c, fspermission/test.c,
fsrdwr/init.c, fssymlink/test.c, fstime/test.c,
mdosfs_support/fs_config.h, mdosfs_support/fs_support.c,
support/fstest.h, support/fstest_support.c,
support/ramdisk_support.c, support/ramdisk_support.h: Perform first
phase of clean up.
* Makefile.am, configure.ac, fslink/fslink.doc, fslink/test.c,
fssymlink/test.c, imfs_fslink/Makefile.am,
imfs_fssymlink/Makefile.am, imfs_support/fs_config.h,
imfs_support/fs_support.c, mdosfs_support/fs_config.h,
mdosfs_support/fs_support.c, mimfs_fslink/Makefile.am,
mimfs_fssymlink/Makefile.am, mimfs_support/fs_config.h,
mimfs_support/fs_support.c, mrfs_fslink/Makefile.am,
mrfs_fssymlink/Makefile.am, mrfs_support/fs_config.h,
support/ramdisk_support.c, support/ramdisk_support.h: Submit correct
tarball of current work.
* fs01/init.c, fsfchx/fsfchx.doc, fsfchx/init.c, fsfile01/fsfile01.doc,
fsfile01/test.c, fsfile01/test_cat.c, fsfile01/test_extend.c,
fsfile01/test_write.c, fsfile02/fsfile02.doc, fsfile02/init.c,
fsfstest/fs-test.c, fsfstest/fsfstest.doc, fsimfs01/fsimfs01.doc,
fsimfs01/init.c, fsimfs02/fsimfs02.doc, fsimfs02/init.c,
fsmkdir/fsmkdir.doc, fsmkdir/test.c, fsopen/fsopen.doc,
fsopen/test.c, fsrdwrv/fsrdwrv.doc, fsrdwrv/test.c,
fsreaddir/fsreaddir.doc, fsreaddir/test.c, fsrename/fsrename.doc,
fsrename/test.c, fsrmdir/test.c, fsrwfile/fsrwfile.doc,
fsrwfile/init.c, fsstat/fsstat.doc, fsstat/test.c,
fstruncate/fstruncate.doc, fstruncate/test.c, imfs_fs01/.cvsignore,
imfs_fs01/Makefile.am, imfs_fs01/imfs_fs01.scn,
imfs_fsfchx/.cvsignore, imfs_fsfchx/Makefile.am,
imfs_fsfile01/.cvsignore, imfs_fsfile01/Makefile.am,
imfs_fsfile02/.cvsignore, imfs_fsfile02/Makefile.am,
imfs_fsfstest/.cvsignore, imfs_fsfstest/Makefile.am,
imfs_fsimfs01/.cvsignore, imfs_fsimfs01/Makefile.am,
imfs_fsimfs02/.cvsignore, imfs_fsimfs02/Makefile.am,
imfs_fslink/.cvsignore, imfs_fsmkdir/.cvsignore,
imfs_fsmkdir/Makefile.am, imfs_fsopen/.cvsignore,
imfs_fsopen/Makefile.am, imfs_fsrdwrv/.cvsignore,
imfs_fsrdwrv/Makefile.am, imfs_fsreaddir/.cvsignore,
imfs_fsreaddir/Makefile.am, imfs_fsrename/.cvsignore,
imfs_fsrename/Makefile.am, imfs_fsrmdir/.cvsignore,
imfs_fsrmdir/Makefile.am, imfs_fsrwfile/.cvsignore,
imfs_fsrwfile/Makefile.am, imfs_fsstat/.cvsignore,
imfs_fsstat/Makefile.am, imfs_fssymlink/.cvsignore,
imfs_fstruncate/.cvsignore, imfs_fstruncate/Makefile.am,
mdosfs_fsfchx/.cvsignore, mdosfs_fsfchx/Makefile.am,
mdosfs_fsfile01/.cvsignore, mdosfs_fsfile01/Makefile.am,
mdosfs_fsfile02/.cvsignore, mdosfs_fsfile02/Makefile.am,
mdosfs_fsfstest/.cvsignore, mdosfs_fsfstest/Makefile.am,
mdosfs_fsimfs01/.cvsignore, mdosfs_fsimfs01/Makefile.am,
mdosfs_fsimfs02/.cvsignore, mdosfs_fsimfs02/Makefile.am,
mdosfs_fslink/.cvsignore, mdosfs_fslink/Makefile.am,
mdosfs_fsmkdir/.cvsignore, mdosfs_fsmkdir/Makefile.am,
mdosfs_fsopen/.cvsignore, mdosfs_fsopen/Makefile.am,
mdosfs_fsrdwrv/.cvsignore, mdosfs_fsrdwrv/Makefile.am,
mdosfs_fsreaddir/.cvsignore, mdosfs_fsreaddir/Makefile.am,
mdosfs_fsrename/.cvsignore, mdosfs_fsrename/Makefile.am,
mdosfs_fsrmdir/.cvsignore, mdosfs_fsrmdir/Makefile.am,
mdosfs_fsrwfile/.cvsignore, mdosfs_fsrwfile/Makefile.am,
mdosfs_fsstat/.cvsignore, mdosfs_fsstat/Makefile.am,
mdosfs_fssymlink/.cvsignore, mdosfs_fssymlink/Makefile.am,
mdosfs_fstruncate/.cvsignore, mdosfs_fstruncate/Makefile.am,
mimfs_fs01/.cvsignore, mimfs_fs01/Makefile.am,
mimfs_fs01/mimfs_fs01.scn, mimfs_fsfchx/.cvsignore,
mimfs_fsfchx/Makefile.am, mimfs_fsfile01/.cvsignore,
mimfs_fsfile01/Makefile.am, mimfs_fsfile02/.cvsignore,
mimfs_fsfile02/Makefile.am, mimfs_fsfstest/.cvsignore,
mimfs_fsfstest/Makefile.am, mimfs_fsimfs01/.cvsignore,
mimfs_fsimfs01/Makefile.am, mimfs_fsimfs02/.cvsignore,
mimfs_fsimfs02/Makefile.am, mimfs_fslink/.cvsignore,
mimfs_fsmkdir/.cvsignore, mimfs_fsmkdir/Makefile.am,
mimfs_fsopen/.cvsignore, mimfs_fsopen/Makefile.am,
mimfs_fsrdwrv/.cvsignore, mimfs_fsrdwrv/Makefile.am,
mimfs_fsreaddir/.cvsignore, mimfs_fsreaddir/Makefile.am,
mimfs_fsrename/.cvsignore, mimfs_fsrename/Makefile.am,
mimfs_fsrmdir/.cvsignore, mimfs_fsrmdir/Makefile.am,
mimfs_fsrwfile/.cvsignore, mimfs_fsrwfile/Makefile.am,
mimfs_fsstat/.cvsignore, mimfs_fsstat/Makefile.am,
mimfs_fssymlink/.cvsignore, mimfs_fstruncate/.cvsignore,
mimfs_fstruncate/Makefile.am, mrfs_fsfchx/.cvsignore,
mrfs_fsfchx/Makefile.am, mrfs_fsfile01/.cvsignore,
mrfs_fsfile01/Makefile.am, mrfs_fsfile02/.cvsignore,
mrfs_fsfile02/Makefile.am, mrfs_fsfstest/.cvsignore,
mrfs_fsfstest/Makefile.am, mrfs_fsimfs01/.cvsignore,
mrfs_fsimfs01/Makefile.am, mrfs_fsimfs02/.cvsignore,
mrfs_fsimfs02/Makefile.am, mrfs_fslink/.cvsignore,
mrfs_fsmkdir/.cvsignore, mrfs_fsmkdir/Makefile.am,
mrfs_fsopen/.cvsignore, mrfs_fsopen/Makefile.am,
mrfs_fsrdwrv/.cvsignore, mrfs_fsrdwrv/Makefile.am,
mrfs_fsreaddir/.cvsignore, mrfs_fsreaddir/Makefile.am,
mrfs_fsrename/.cvsignore, mrfs_fsrename/Makefile.am,
mrfs_fsrmdir/.cvsignore, mrfs_fsrmdir/Makefile.am,
mrfs_fsrwfile/.cvsignore, mrfs_fsrwfile/Makefile.am,
mrfs_fsstat/.cvsignore, mrfs_fsstat/Makefile.am,
mrfs_fssymlink/.cvsignore, mrfs_fstruncate/.cvsignore,
mrfs_fstruncate/Makefile.am: Removed.
* Makefile.am, configure.ac, imfs_support/fs_config.h,
imfs_support/fs_support.c, mimfs_support/fs_config.h,
mimfs_support/fs_support.c: Add initial version of new filesystem
tests. There are multiple failures which need to be addressed by the
community.
* fsfchx/fsfchx.doc, fsfchx/init.c, fsfile01/fsfile01.doc,
fslink/fslink.doc, fslink/test.c, fsmkdir/fsmkdir.doc,
fsmkdir/test.c, fsopen/fsopen.doc, fsopen/test.c,
fsrdwrv/fsrdwrv.doc, fsrdwrv/test.c, fsreaddir/fsreaddir.doc,
fsreaddir/test.c, fsrename/fsrename.doc, fsrename/test.c,
fsrmdir/test.c, fsrwfile/fsrwfile.doc, fsrwfile/init.c,
fsstat/fsstat.doc, fsstat/test.c, fssymlink/fssymlink.doc,
fssymlink/test.c, fstruncate/fstruncate.doc, fstruncate/test.c,
imfs_fslink/.cvsignore, imfs_fslink/Makefile.am,
imfs_fsmkdir/.cvsignore, imfs_fsmkdir/Makefile.am,
imfs_fsopen/.cvsignore, imfs_fsopen/Makefile.am,
imfs_fsrdwrv/.cvsignore, imfs_fsrdwrv/Makefile.am,
imfs_fsreaddir/.cvsignore, imfs_fsreaddir/Makefile.am,
imfs_fsrename/.cvsignore, imfs_fsrename/Makefile.am,
imfs_fsrmdir/.cvsignore, imfs_fsrmdir/Makefile.am,
imfs_fsrwfile/.cvsignore, imfs_fsrwfile/Makefile.am,
imfs_fsstat/.cvsignore, imfs_fsstat/Makefile.am,
imfs_fssymlink/.cvsignore, imfs_fssymlink/Makefile.am,
mimfs_fsfchx/.cvsignore, mimfs_fsfchx/Makefile.am,
mimfs_fsfile01/.cvsignore, mimfs_fsfile01/Makefile.am,
mimfs_fsfile02/.cvsignore, mimfs_fsfile02/Makefile.am,
mimfs_fsfstest/.cvsignore, mimfs_fsfstest/Makefile.am,
mimfs_fsimfs01/.cvsignore, mimfs_fsimfs01/Makefile.am,
mimfs_fsimfs02/.cvsignore, mimfs_fsimfs02/Makefile.am,
mimfs_fslink/.cvsignore, mimfs_fslink/Makefile.am,
mimfs_fssymlink/.cvsignore, mimfs_fssymlink/Makefile.am,
mimfs_fstruncate/.cvsignore, mimfs_fstruncate/Makefile.am,
mrfs_fsfchx/.cvsignore, mrfs_fsfchx/Makefile.am,
mrfs_fsfile01/.cvsignore, mrfs_fsfile01/Makefile.am,
mrfs_fsfile02/.cvsignore, mrfs_fsfile02/Makefile.am,
mrfs_fsfstest/.cvsignore, mrfs_fsfstest/Makefile.am,
mrfs_fsimfs01/.cvsignore, mrfs_fsimfs01/Makefile.am,
mrfs_fsimfs02/.cvsignore, mrfs_fsimfs02/Makefile.am,
mrfs_fslink/.cvsignore, mrfs_fslink/Makefile.am,
mrfs_fssymlink/.cvsignore, mrfs_fssymlink/Makefile.am,
mrfs_fstruncate/.cvsignore, mrfs_fstruncate/Makefile.am,
mrfs_support/fs_config.h, mrfs_support/fs_support.c,
support/fstest.h, support/fstest_support.c, support/fstest_support.h,
support/ramdisk_support.c, support/ramdisk_support.h: New files.
