path: root/testsuites/fstests/mdosfs_fserror (unfollow)
2013-11-15testsuites: Add missing .scn filesJoel Sherrill2-1/+97
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-4/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-07Revert: Remove CVS IdsJoel Sherrill1-0/+5
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04Remove CVS-Ids.Ralf Corsépius1-5/+0
2012-02-01Remove all .cvsignore files.Joel Sherrill1-2/+0
2011-12-082011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-3/+1
PR 1589/build * imfs_fserror/Makefile.am, imfs_fslink/Makefile.am, imfs_fspatheval/Makefile.am, imfs_fspermission/Makefile.am, imfs_fsrdwr/Makefile.am, imfs_fssymlink/Makefile.am, imfs_fstime/Makefile.am, mdosfs_fserror/Makefile.am, mdosfs_fspatheval/Makefile.am, mdosfs_fsrdwr/Makefile.am, mdosfs_fstime/Makefile.am, mimfs_fserror/Makefile.am, mimfs_fslink/Makefile.am, mimfs_fspatheval/Makefile.am, mimfs_fspermission/Makefile.am, mimfs_fsrdwr/Makefile.am, mimfs_fssymlink/Makefile.am, mimfs_fstime/Makefile.am, mrfs_fserror/Makefile.am, mrfs_fslink/Makefile.am, mrfs_fspatheval/Makefile.am, mrfs_fspermission/Makefile.am, mrfs_fsrdwr/Makefile.am, mrfs_fssymlink/Makefile.am, mrfs_fstime/Makefile.am: Remove obsolete optional manager capability.
2011-08-012011-08-01 Xiang Cui <medivhc@gmail.com>Joel Sherrill2-0/+41
* imfs_fslink/Makefile.am, imfs_fssymlink/Makefile.am, mimfs_fslink/Makefile.am, mimfs_fssymlink/Makefile.am, mrfs_fslink/Makefile.am, mrfs_fssymlink/Makefile.am, mrfs_support/fs_config.h: Correcting from previous commit of incorrect tarball. * fserror/fserror.doc, fserror/test.c, fspatheval/patheval.doc, fspatheval/test.c, fspermission/fspermission.doc, fspermission/test.c, fsrdwr/fsrdwr.doc, fsrdwr/init.c, fstime/fstime.doc, fstime/test.c, imfs_fserror/.cvsignore, imfs_fserror/Makefile.am, imfs_fslink/.cvsignore, imfs_fspatheval/.cvsignore, imfs_fspatheval/Makefile.am, imfs_fspermission/.cvsignore, imfs_fspermission/Makefile.am, imfs_fsrdwr/.cvsignore, imfs_fsrdwr/Makefile.am, imfs_fssymlink/.cvsignore, imfs_fstime/.cvsignore, imfs_fstime/Makefile.am, imfs_support/fs_supprot.h, mdosfs_fserror/.cvsignore, mdosfs_fserror/Makefile.am, mdosfs_fspatheval/.cvsignore, mdosfs_fspatheval/Makefile.am, mdosfs_fsrdwr/.cvsignore, mdosfs_fsrdwr/Makefile.am, mdosfs_fstime/.cvsignore, mdosfs_fstime/Makefile.am, mimfs_fserror/.cvsignore, mimfs_fserror/Makefile.am, mimfs_fslink/.cvsignore, mimfs_fspatheval/.cvsignore, mimfs_fspatheval/Makefile.am, mimfs_fspermission/.cvsignore, mimfs_fspermission/Makefile.am, mimfs_fsrdwr/.cvsignore, mimfs_fsrdwr/Makefile.am, mimfs_fssymlink/.cvsignore, mimfs_fstime/.cvsignore, mimfs_fstime/Makefile.am, mrfs_fserror/.cvsignore, mrfs_fserror/Makefile.am, mrfs_fslink/.cvsignore, mrfs_fspatheval/.cvsignore, mrfs_fspatheval/Makefile.am, mrfs_fspermission/.cvsignore, mrfs_fspermission/Makefile.am, mrfs_fsrdwr/.cvsignore, mrfs_fsrdwr/Makefile.am, mrfs_fssymlink/.cvsignore, mrfs_fstime/.cvsignore, mrfs_fstime/Makefile.am: New files.
