* | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 2014-12-16 | 1 | -1/+0 |
| | | | | This define was superfluous, undocumented and used inconsistently. | ||||
* | privateenv: Use POSIX keys instead of task variables. | Christian Mauderer | 2014-03-27 | 1 | -0/+2 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | tests/fstests: Use <rtems/test.h> | Sebastian Huber | 2014-03-17 | 1 | -0/+3 |
* | JFFS2: New tests | Sebastian Huber | 2013-09-19 | 2 | -0/+180 |
