path: root/testsuites/fstests/jffs2_support/fs_support.c (follow)
* libio: Add POSIX user environment pointer to TCBSebastian Huber2020-02-251-2/+0
| | | | | | | | | | The IO library used a POSIX key to store an optional POSIX user environment pointer. This pulled in the POSIX keys support in every application configuration. Add a user environment pointer to the thread control block (TCB) instead. Applications which do not need the POSIX user environment will just get an overhead of one pointer per thread. Close #3882.
* config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORSSebastian Huber2019-12-191-1/+1
| | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753.
* fstests: Use tmacros.h instead of pmacros.hSebastian Huber2019-11-121-1/+1
| | | | | | This avoids an extra include path. Update #3818.
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* tests: Use floating point taskSebastian Huber2017-07-181-0/+1
| | | | | | | These tests directly or indirectly use fprintf(), etc. which may use the floating point unit. Update #3076.
* Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEMSebastian Huber2014-12-161-1/+0
| | | | This define was superfluous, undocumented and used inconsistently.
* privateenv: Use POSIX keys instead of task variables.Christian Mauderer2014-03-271-0/+2
* tests/fstests: Use <rtems/test.h>Sebastian Huber2014-03-171-0/+3
* JFFS2: New testsSebastian Huber2013-09-191-0/+160
