* | jffs2: Move into separate library | Sebastian Huber | 2015-05-27 | 1 | -1/+2 |
| | | | | | | | In case the zlib compression was used, then the librtemscpu.a depended on libz.a. To avoid a GCC patch or complicated link flags move the JFFS2 support into a separate library to use a simple "-ljffs2 -lz" to link the executable. | ||||
* | testsuites: Add missing .scn files | Joel Sherrill | 2013-11-15 | 2 | -1/+17 |
* | JFFS2: New tests | Sebastian Huber | 2013-09-19 | 1 | -0/+31 |
