path: root/testsuites/fstests/imfs_fslink (follow)
* IMFS: Generating .scn (Screen Shots) #2Christopher Kerl2013-01-021-0/+15
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | PR 1589/build * imfs_fserror/Makefile.am, imfs_fslink/Makefile.am, imfs_fspatheval/Makefile.am, imfs_fspermission/Makefile.am, imfs_fsrdwr/Makefile.am, imfs_fssymlink/Makefile.am, imfs_fstime/Makefile.am, mdosfs_fserror/Makefile.am, mdosfs_fspatheval/Makefile.am, mdosfs_fsrdwr/Makefile.am, mdosfs_fstime/Makefile.am, mimfs_fserror/Makefile.am, mimfs_fslink/Makefile.am, mimfs_fspatheval/Makefile.am, mimfs_fspermission/Makefile.am, mimfs_fsrdwr/Makefile.am, mimfs_fssymlink/Makefile.am, mimfs_fstime/Makefile.am, mrfs_fserror/Makefile.am, mrfs_fslink/Makefile.am, mrfs_fspatheval/Makefile.am, mrfs_fspermission/Makefile.am, mrfs_fsrdwr/Makefile.am, mrfs_fssymlink/Makefile.am, mrfs_fstime/Makefile.am: Remove obsolete optional manager capability.
* 2011-08-01 Xiang Cui <medivhc@gmail.com>Joel Sherrill2011-08-012-4/+9
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * imfs_fslink/Makefile.am, imfs_fssymlink/Makefile.am, mimfs_fslink/Makefile.am, mimfs_fssymlink/Makefile.am, mrfs_fslink/Makefile.am, mrfs_fssymlink/Makefile.am, mrfs_support/fs_config.h: Correcting from previous commit of incorrect tarball. * fserror/fserror.doc, fserror/test.c, fspatheval/patheval.doc, fspatheval/test.c, fspermission/fspermission.doc, fspermission/test.c, fsrdwr/fsrdwr.doc, fsrdwr/init.c, fstime/fstime.doc, fstime/test.c, imfs_fserror/.cvsignore, imfs_fserror/Makefile.am, imfs_fslink/.cvsignore, imfs_fspatheval/.cvsignore, imfs_fspatheval/Makefile.am, imfs_fspermission/.cvsignore, imfs_fspermission/Makefile.am, imfs_fsrdwr/.cvsignore, imfs_fsrdwr/Makefile.am, imfs_fssymlink/.cvsignore, imfs_fstime/.cvsignore, imfs_fstime/Makefile.am, imfs_support/fs_supprot.h, mdosfs_fserror/.cvsignore, mdosfs_fserror/Makefile.am, mdosfs_fspatheval/.cvsignore, mdosfs_fspatheval/Makefile.am, mdosfs_fsrdwr/.cvsignore, mdosfs_fsrdwr/Makefile.am, mdosfs_fstime/.cvsignore, mdosfs_fstime/Makefile.am, mimfs_fserror/.cvsignore, mimfs_fserror/Makefile.am, mimfs_fslink/.cvsignore, mimfs_fspatheval/.cvsignore, mimfs_fspatheval/Makefile.am, mimfs_fspermission/.cvsignore, mimfs_fspermission/Makefile.am, mimfs_fsrdwr/.cvsignore, mimfs_fsrdwr/Makefile.am, mimfs_fssymlink/.cvsignore, mimfs_fstime/.cvsignore, mimfs_fstime/Makefile.am, mrfs_fserror/.cvsignore, mrfs_fserror/Makefile.am, mrfs_fslink/.cvsignore, mrfs_fspatheval/.cvsignore, mrfs_fspatheval/Makefile.am, mrfs_fspermission/.cvsignore, mrfs_fspermission/Makefile.am, mrfs_fsrdwr/.cvsignore, mrfs_fsrdwr/Makefile.am, mrfs_fssymlink/.cvsignore, mrfs_fstime/.cvsignore, mrfs_fstime/Makefile.am: New files.
* 2011-08-01 Xiang Cui <medivhc@gmail.com>Joel Sherrill2011-08-011-0/+34
* Makefile.am, configure.ac, imfs_support/fs_config.h, imfs_support/fs_support.c, mimfs_support/fs_config.h, mimfs_support/fs_support.c: Add initial version of new filesystem tests. There are multiple failures which need to be addressed by the community. * fsfchx/fsfchx.doc, fsfchx/init.c, fsfile01/fsfile01.doc, fsfile01/test.c, fsfile01/test_cat.c, fsfile01/test_extend.c, fsfile01/test_write.c, fsfile02/fsfile02.doc, fsfile02/init.c, fsfstest/fs-test.c, fsfstest/fsfstest.doc, fsimfs01/fsimfs01.doc, fsimfs01/init.c, fsimfs02/fsimfs02.doc, fsimfs02/init.c, fslink/fslink.doc, fslink/test.c, fsmkdir/fsmkdir.doc, fsmkdir/test.c, fsopen/fsopen.doc, fsopen/test.c, fsrdwrv/fsrdwrv.doc, fsrdwrv/test.c, fsreaddir/fsreaddir.doc, fsreaddir/test.c, fsrename/fsrename.doc, fsrename/test.c, fsrmdir/test.c, fsrwfile/fsrwfile.doc, fsrwfile/init.c, fsstat/fsstat.doc, fsstat/test.c, fssymlink/fssymlink.doc, fssymlink/test.c, fstruncate/fstruncate.doc, fstruncate/test.c, imfs_fsfchx/.cvsignore, imfs_fsfchx/Makefile.am, imfs_fsfile01/.cvsignore, imfs_fsfile01/Makefile.am, imfs_fsfile02/.cvsignore, imfs_fsfile02/Makefile.am, imfs_fsfstest/.cvsignore, imfs_fsfstest/Makefile.am, imfs_fsimfs01/.cvsignore, imfs_fsimfs01/Makefile.am, imfs_fsimfs02/.cvsignore, imfs_fsimfs02/Makefile.am, imfs_fslink/.cvsignore, imfs_fslink/Makefile.am, imfs_fsmkdir/.cvsignore, imfs_fsmkdir/Makefile.am, imfs_fsopen/.cvsignore, imfs_fsopen/Makefile.am, imfs_fsrdwrv/.cvsignore, imfs_fsrdwrv/Makefile.am, imfs_fsreaddir/.cvsignore, imfs_fsreaddir/Makefile.am, imfs_fsrename/.cvsignore, imfs_fsrename/Makefile.am, imfs_fsrmdir/.cvsignore, imfs_fsrmdir/Makefile.am, imfs_fsrwfile/.cvsignore, imfs_fsrwfile/Makefile.am, imfs_fsstat/.cvsignore, imfs_fsstat/Makefile.am, imfs_fssymlink/.cvsignore, imfs_fssymlink/Makefile.am, imfs_fstruncate/.cvsignore, imfs_fstruncate/Makefile.am, mdosfs_fsfchx/.cvsignore, mdosfs_fsfchx/Makefile.am, mdosfs_fsfile01/.cvsignore, mdosfs_fsfile01/Makefile.am, mdosfs_fsfile02/.cvsignore, mdosfs_fsfile02/Makefile.am, mdosfs_fsfstest/.cvsignore, mdosfs_fsfstest/Makefile.am, mdosfs_fsimfs01/.cvsignore, mdosfs_fsimfs01/Makefile.am, mdosfs_fsimfs02/.cvsignore, mdosfs_fsimfs02/Makefile.am, mdosfs_fslink/.cvsignore, mdosfs_fslink/Makefile.am, mdosfs_fsmkdir/.cvsignore, mdosfs_fsmkdir/Makefile.am, mdosfs_fsopen/.cvsignore, mdosfs_fsopen/Makefile.am, mdosfs_fsrdwrv/.cvsignore, mdosfs_fsrdwrv/Makefile.am, mdosfs_fsreaddir/.cvsignore, mdosfs_fsreaddir/Makefile.am, mdosfs_fsrename/.cvsignore, mdosfs_fsrename/Makefile.am, mdosfs_fsrmdir/.cvsignore, mdosfs_fsrmdir/Makefile.am, mdosfs_fsrwfile/.cvsignore, mdosfs_fsrwfile/Makefile.am, mdosfs_fsstat/.cvsignore, mdosfs_fsstat/Makefile.am, mdosfs_fssymlink/.cvsignore, mdosfs_fssymlink/Makefile.am, mdosfs_fstruncate/.cvsignore, mdosfs_fstruncate/Makefile.am, mdosfs_support/fs_config.h, mdosfs_support/fs_support.c, mimfs_fsfchx/.cvsignore, mimfs_fsfchx/Makefile.am, mimfs_fsfile01/.cvsignore, mimfs_fsfile01/Makefile.am, mimfs_fsfile02/.cvsignore, mimfs_fsfile02/Makefile.am, mimfs_fsfstest/.cvsignore, mimfs_fsfstest/Makefile.am, mimfs_fsimfs01/.cvsignore, mimfs_fsimfs01/Makefile.am, mimfs_fsimfs02/.cvsignore, mimfs_fsimfs02/Makefile.am, mimfs_fslink/.cvsignore, mimfs_fslink/Makefile.am, mimfs_fsmkdir/.cvsignore, mimfs_fsmkdir/Makefile.am, mimfs_fsopen/.cvsignore, mimfs_fsopen/Makefile.am, mimfs_fsrdwrv/.cvsignore, mimfs_fsrdwrv/Makefile.am, mimfs_fsreaddir/.cvsignore, mimfs_fsreaddir/Makefile.am, mimfs_fsrename/.cvsignore, mimfs_fsrename/Makefile.am, mimfs_fsrmdir/.cvsignore, mimfs_fsrmdir/Makefile.am, mimfs_fsrwfile/.cvsignore, mimfs_fsrwfile/Makefile.am, mimfs_fsstat/.cvsignore, mimfs_fsstat/Makefile.am, mimfs_fssymlink/.cvsignore, mimfs_fssymlink/Makefile.am, mimfs_fstruncate/.cvsignore, mimfs_fstruncate/Makefile.am, mrfs_fsfchx/.cvsignore, mrfs_fsfchx/Makefile.am, mrfs_fsfile01/.cvsignore, mrfs_fsfile01/Makefile.am, mrfs_fsfile02/.cvsignore, mrfs_fsfile02/Makefile.am, mrfs_fsfstest/.cvsignore, mrfs_fsfstest/Makefile.am, mrfs_fsimfs01/.cvsignore, mrfs_fsimfs01/Makefile.am, mrfs_fsimfs02/.cvsignore, mrfs_fsimfs02/Makefile.am, mrfs_fslink/.cvsignore, mrfs_fslink/Makefile.am, mrfs_fsmkdir/.cvsignore, mrfs_fsmkdir/Makefile.am, mrfs_fsopen/.cvsignore, mrfs_fsopen/Makefile.am, mrfs_fsrdwrv/.cvsignore, mrfs_fsrdwrv/Makefile.am, mrfs_fsreaddir/.cvsignore, mrfs_fsreaddir/Makefile.am, mrfs_fsrename/.cvsignore, mrfs_fsrename/Makefile.am, mrfs_fsrmdir/.cvsignore, mrfs_fsrmdir/Makefile.am, mrfs_fsrwfile/.cvsignore, mrfs_fsrwfile/Makefile.am, mrfs_fsstat/.cvsignore, mrfs_fsstat/Makefile.am, mrfs_fssymlink/.cvsignore, mrfs_fssymlink/Makefile.am, mrfs_fstruncate/.cvsignore, mrfs_fstruncate/Makefile.am, mrfs_support/fs_config.h, mrfs_support/fs_support.c, support/fstest.h, support/fstest_support.c, support/fstest_support.h, support/ramdisk_support.c, support/ramdisk_support.h: New files.
