* | tests/fstests: Use <rtems/test.h> | Sebastian Huber | 2014-03-17 | 1 | -3/+6 |
* | Filesystem: Read-only file system checks | Sebastian Huber | 2012-03-13 | 4 | -0/+221 |
o Make sure EROFS is indicated for write operations on a read-only file system. o Add error indication for read-only file systems in fchmod() and fchown() according to POSIX. |
