2020-04-16 | Canonicalize config.h include | Sebastian Huber | 1 | -1/+1 | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||||
2019-01-07 | Fix format warnings | Sebastian Huber | 1 | -18/+18 | |
2018-04-11 | fstest/fsrfsbitmap01: Update RFS bitmap tests to test fixes. | Chris Johns | 1 | -0/+19 | |
Add tests to check the patches for this ticket exist and are fixed. Close #3089 | |||||
2018-04-10 | testsuite/fstests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 1 | -33/+0 | |
This change is part of the testsuite Makefile.am reorganization. Update #3382 | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 2 | -2/+2 | |
2014-03-17 | tests/fstests: Use <rtems/test.h> | Sebastian Huber | 1 | -0/+3 | |
2012-11-13 | fstests/fsrfsbitmap01: Fix NULL pointer access | Sebastian Huber | 3 | -55/+65 | |
Move test files into one directory. | |||||
2012-10-15 | Make tems_rfs_bitmap_ut_test_range, rtems_rfs_bitmap_ut_alloc_seq_test, ↵ | Ralf Corsépius | 1 | -6/+6 | |
rtems_rfs_bitmap_ut_test_bitmap, rtems_rfs_bitmap_unit_test, nullpointer_test, open_failure static. | |||||
2012-10-11 | Use %zu instead of %lu to print size_t's. | Ralf Corsépius | 1 | -1/+1 | |
2012-10-11 | Cleanup Krzysztof's copyright notices. | Ralf Corsépius | 2 | -4/+4 | |
2012-10-01 | fsrfsbitmap01/test.c: Remove tabs | Joel Sherrill | 1 | -7/+8 | |
2012-10-01 | misc fstests: Remove spaces at EOL | Joel Sherrill | 2 | -12/+9 | |
2012-10-01 | New fstest to cover RFS bitmaps - fsrfsbitmap01 | Krzysztof Miesowicz | 3 | -0/+708 | |
