path: root/testsuites/fstests/fspatheval (follow)
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* tests/fstests: Remove duplicate begin/end messagesSebastian Huber2014-03-201-2/+0
| | | | Fix file system names. Remove superfluous defines.
* tests/fstests: Use <rtems/test.h>Sebastian Huber2014-03-171-0/+3
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-112-5/+0
* Fixed warnings and minor bugsSebastian Huber2012-02-081-4/+4
| | | | | | o Due to the usual integer propagation rules care must be taken in case off_t is involved. o Use the effective UID and GID consistently.
* 2011-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-301-0/+1
| | | | | | | | * fserror/test.c, fslink/test.c, fspatheval/test.c, fspermission/test.c, fsrdwr/init.c, fssymlink/test.c, fstime/test.c, support/fstest_support.c, support/ramdisk_support.c: Explicitly include "pmacros.h". * support/fstest.h: Don't include "pmacros.h".
* 2011-09-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-071-0/+5
| | | | | | | * fserror/test.c, fslink/test.c, fspatheval/test.c, fspermission/test.c, fsrdwr/init.c, fssymlink/test.c, fstime/test.c, support/fstest_support.c, support/ramdisk_support.c: Add config-header support.
* 2011-09-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-071-1/+1
| | | | | | | | | | | | | | | | * fserror/fserror.doc, fserror/test.c, fslink/fslink.doc, fslink/test.c, fspatheval/patheval.doc, fspatheval/test.c, fspermission/fspermission.doc, fspermission/test.c, fsrdwr/fsrdwr.doc, fsrdwr/init.c, fssymlink/fssymlink.doc, fssymlink/test.c, fstime/fstime.doc, fstime/test.c, imfs_support/fs_config.h, imfs_support/fs_support.c, imfs_support/fs_supprot.h, mdosfs_support/fs_config.h, mdosfs_support/fs_support.c, mimfs_support/fs_config.h, mimfs_support/fs_support.c, mrfs_support/fs_config.h, mrfs_support/fs_support.c, support/fstest.h, support/fstest_support.c, support/fstest_support.h, support/ramdisk_support.c, support/ramdisk_support.h: Fix CVS-Ids.
* 2011-08-01 Xiang Cui <medivhc@gmail.com>Joel Sherrill2011-08-012-0/+213
* imfs_fslink/Makefile.am, imfs_fssymlink/Makefile.am, mimfs_fslink/Makefile.am, mimfs_fssymlink/Makefile.am, mrfs_fslink/Makefile.am, mrfs_fssymlink/Makefile.am, mrfs_support/fs_config.h: Correcting from previous commit of incorrect tarball. * fserror/fserror.doc, fserror/test.c, fspatheval/patheval.doc, fspatheval/test.c, fspermission/fspermission.doc, fspermission/test.c, fsrdwr/fsrdwr.doc, fsrdwr/init.c, fstime/fstime.doc, fstime/test.c, imfs_fserror/.cvsignore, imfs_fserror/Makefile.am, imfs_fslink/.cvsignore, imfs_fspatheval/.cvsignore, imfs_fspatheval/Makefile.am, imfs_fspermission/.cvsignore, imfs_fspermission/Makefile.am, imfs_fsrdwr/.cvsignore, imfs_fsrdwr/Makefile.am, imfs_fssymlink/.cvsignore, imfs_fstime/.cvsignore, imfs_fstime/Makefile.am, imfs_support/fs_supprot.h, mdosfs_fserror/.cvsignore, mdosfs_fserror/Makefile.am, mdosfs_fspatheval/.cvsignore, mdosfs_fspatheval/Makefile.am, mdosfs_fsrdwr/.cvsignore, mdosfs_fsrdwr/Makefile.am, mdosfs_fstime/.cvsignore, mdosfs_fstime/Makefile.am, mimfs_fserror/.cvsignore, mimfs_fserror/Makefile.am, mimfs_fslink/.cvsignore, mimfs_fspatheval/.cvsignore, mimfs_fspatheval/Makefile.am, mimfs_fspermission/.cvsignore, mimfs_fspermission/Makefile.am, mimfs_fsrdwr/.cvsignore, mimfs_fsrdwr/Makefile.am, mimfs_fssymlink/.cvsignore, mimfs_fstime/.cvsignore, mimfs_fstime/Makefile.am, mrfs_fserror/.cvsignore, mrfs_fserror/Makefile.am, mrfs_fslink/.cvsignore, mrfs_fspatheval/.cvsignore, mrfs_fspatheval/Makefile.am, mrfs_fspermission/.cvsignore, mrfs_fspermission/Makefile.am, mrfs_fsrdwr/.cvsignore, mrfs_fsrdwr/Makefile.am, mrfs_fssymlink/.cvsignore, mrfs_fstime/.cvsignore, mrfs_fstime/Makefile.am: New files.
