o Due to the usual integer propagation rules care must be taken in case
off_t is involved.
o Use the effective UID and GID consistently.
* fserror/test.c, fslink/test.c, fspatheval/test.c,
fspermission/test.c, fsrdwr/init.c, fssymlink/test.c,
fstime/test.c, support/fstest_support.c, support/ramdisk_support.c:
Explicitly include "pmacros.h".
* support/fstest.h: Don't include "pmacros.h".
Add config-header support.
* fserror/fserror.doc, fserror/test.c, fslink/fslink.doc,
fslink/test.c, fspatheval/patheval.doc, fspatheval/test.c,
fspermission/fspermission.doc, fspermission/test.c,
fsrdwr/fsrdwr.doc, fsrdwr/init.c, fssymlink/fssymlink.doc,
fssymlink/test.c, fstime/fstime.doc, fstime/test.c,
imfs_support/fs_config.h, imfs_support/fs_support.c,
imfs_support/fs_supprot.h, mdosfs_support/fs_config.h,
mdosfs_support/fs_support.c, mimfs_support/fs_config.h,
mimfs_support/fs_support.c, mrfs_support/fs_config.h,
mrfs_support/fs_support.c, support/fstest.h,
support/fstest_support.c, support/fstest_support.h,
support/ramdisk_support.c, support/ramdisk_support.h:
Fix CVS-Ids.
* imfs_fslink/Makefile.am, imfs_fssymlink/Makefile.am,
mimfs_fslink/Makefile.am, mimfs_fssymlink/Makefile.am,
mrfs_fslink/Makefile.am, mrfs_fssymlink/Makefile.am,
mrfs_support/fs_config.h: Correcting from previous commit of
incorrect tarball.
* fserror/fserror.doc, fserror/test.c, fspatheval/patheval.doc,
fspatheval/test.c, fspermission/fspermission.doc,
fspermission/test.c, fsrdwr/fsrdwr.doc, fsrdwr/init.c,
fstime/fstime.doc, fstime/test.c, imfs_fserror/.cvsignore,
imfs_fserror/Makefile.am, imfs_fslink/.cvsignore,
imfs_fspatheval/.cvsignore, imfs_fspatheval/Makefile.am,
imfs_fspermission/.cvsignore, imfs_fspermission/Makefile.am,
imfs_fsrdwr/.cvsignore, imfs_fsrdwr/Makefile.am,
imfs_fssymlink/.cvsignore, imfs_fstime/.cvsignore,
imfs_fstime/Makefile.am, imfs_support/fs_supprot.h,
mdosfs_fserror/.cvsignore, mdosfs_fserror/Makefile.am,
mdosfs_fspatheval/.cvsignore, mdosfs_fspatheval/Makefile.am,
mdosfs_fsrdwr/.cvsignore, mdosfs_fsrdwr/Makefile.am,
mdosfs_fstime/.cvsignore, mdosfs_fstime/Makefile.am,
mimfs_fserror/.cvsignore, mimfs_fserror/Makefile.am,
mimfs_fslink/.cvsignore, mimfs_fspatheval/.cvsignore,
mimfs_fspatheval/Makefile.am, mimfs_fspermission/.cvsignore,
mimfs_fspermission/Makefile.am, mimfs_fsrdwr/.cvsignore,
mimfs_fsrdwr/Makefile.am, mimfs_fssymlink/.cvsignore,
mimfs_fstime/.cvsignore, mimfs_fstime/Makefile.am,
mrfs_fserror/.cvsignore, mrfs_fserror/Makefile.am,
mrfs_fslink/.cvsignore, mrfs_fspatheval/.cvsignore,
mrfs_fspatheval/Makefile.am, mrfs_fspermission/.cvsignore,
mrfs_fspermission/Makefile.am, mrfs_fsrdwr/.cvsignore,
mrfs_fsrdwr/Makefile.am, mrfs_fssymlink/.cvsignore,
mrfs_fstime/.cvsignore, mrfs_fstime/Makefile.am: New files.
