Update #3753.
Update #3382
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
This avoids problems with console drivers that require a more complete
IMFS.
Resurrect CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM.
