2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-04-07 | testsuites/fstests/*: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2022-03-10 | bsps/testsuites/: Scripted embedded brains header file clean up | Joel Sherrill | 1 | -6/+0 | |
Updates #4625. | |||||
2020-04-16 | Canonicalize config.h include | Sebastian Huber | 1 | -1/+1 | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||||
2019-12-19 | config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS | Sebastian Huber | 1 | -1/+1 | |
Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753. | |||||
2018-04-10 | testsuite/fstests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 1 | -19/+0 | |
This change is part of the testsuite Makefile.am reorganization. Update #3382 | |||||
2017-11-06 | tests: Use simple console driver | Sebastian Huber | 1 | -1/+1 | |
Update #3170. Update #3199. | |||||
2017-10-28 | tests: Remove TEST_INIT | Sebastian Huber | 1 | -2/+0 | |
The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | |||||
2017-10-23 | testsuite: Use printk for all test output where possible. | Chris Johns | 1 | -0/+2 | |
- Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | |||||
2015-04-08 | fstests/fsfseeko01: Fix for long == off_t | Sebastian Huber | 1 | -4/+11 | |
Close #2317. | |||||
2014-12-16 | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 1 | -2/+0 | |
This define was superfluous, undocumented and used inconsistently. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2014-03-17 | tests/fstests: Use <rtems/test.h> | Sebastian Huber | 1 | -3/+6 | |
2012-11-22 | fstests/fsfseeko01: Add test cases | Sebastian Huber | 1 | -4/+26 | |
2012-10-01 | misc fstests: Remove spaces at EOL | Joel Sherrill | 1 | -1/+1 | |
2012-06-19 | fstests/fsfseeko01: New test | Sebastian Huber | 4 | -0/+117 | |
