* | testsuite/fstests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -19/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | fstests/fsfseeko01: Fix for long == off_t | Sebastian Huber | 2015-04-08 | 1 | -4/+11 |
| | | | | Close #2317. | ||||
* | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 2014-12-16 | 1 | -2/+0 |
| | | | | This define was superfluous, undocumented and used inconsistently. | ||||
* | tests/fstests: Use <rtems/test.h> | Sebastian Huber | 2014-03-17 | 1 | -3/+6 |
* | fstests/fsfseeko01: Add test cases | Sebastian Huber | 2012-11-22 | 1 | -4/+26 |
* | misc fstests: Remove spaces at EOL | Joel Sherrill | 2012-10-01 | 1 | -1/+1 |
* | fstests/fsfseeko01: New test | Sebastian Huber | 2012-06-19 | 4 | -0/+117 |
